before i use proxy i have odometer on 220kkm level ecu, dash etc.
after proxy ecu have 330kkm all rest still have 220kkkm
i check this on old fes too, odometer in ecu has change to 330kkm.
what do you think? about this?
cheers
p.s.
i still have problems with proxy procedure
of course i can connect to my climate control.CURRENTLY CONFIGURED CAN MODULES:
Body Computer Node (NBC)
Engine Control Node (NCM)
Electric Steering Node (NGE)
Dashboard Node (NQS)
Steering Wheel Controls Node (NVO)
Brake System Node (NFR)
Info-Telematic/Convergence Node (NIT/NCV)
Driver Door Node (NPG)
Boot Node (NVB)
Climate Control Node (NCL)
Steering Angle Sensor Node (NAS)
Passenger Door Node (NPP)
Driver Seat Node (NAG)
Passenger Seat Node (NAP)
Parking Sensor Node (NSP)
Boot Node (NVB)
2012-01-15 01:07:47
CONNECTED TO:
FIAT STILO 1.9 JTD
Body Computer Node (NBC):
Engine Control Node (NCM):
Electric Steering Node (NGE):
Dashboard Node (NQS):
Steering Wheel Controls Node (NVO):
Brake System Node (NFR):
Info-Telematic/Convergence Node (NIT/NCV):
Driver Door Node (NPG):
Boot Node (NVB):
Climate Control Node (NCL):
Steering Angle Sensor Node (NAS):
Passenger Door Node (NPP):
Driver Seat Node (NAG):
Passenger Seat Node (NAP):
Parking Sensor Node (NSP):
Boot Node (NVB):
EXECUTING ADJUSTMENT...
Automatic headlights switch-on - DON'T WORK body don't see switch i auto mode - cables, signal all ok - i check this on body
Old value: Disabled
New value: Enabled
COMPLETED
Writing to module: Climate Control Node (NCL) FAILED! - Unknown error
Writing to module: Parking Sensor Node (NSP) SUCCESS!
FAILED TO EXECUTE
Unknown error
ps2
my mechanic have FES 3.3
