Simulation mode - 3.3
Swiko
Post by Swiko »
All together with version 3.3 simulation mode stopped working.
Try to fix it, please :).
Re: Simulation mode - 3.3
I've just tested and it is working for me. Can you give any more information please?
Swiko
Post by Swiko »
s130 wrote:I've just tested and it is working for me. Can you give any more information please?
Well, anytime when I press CTRL+F10 it's trying to connect in regular mode. So I'm getting message: Connection Failed! You need ELM327/OBDKey to connect this module... I'll try to connect it to my car tomorrow as it's windy and raining all day today.
P.S. I tried unregistered version on my desktop and everything works fine.
P.S.2. My CTRL and F10 buttons are workin' fine as well :mrgreen:.
UPDATE:
All functions which needs an adaptor are working fine in simulation mode. Everything what's using regular ELM/OBDkey interface is trying to connect in normal mode instead of simulation. I've checked this with a couple of cars - all with the same result.
Ok, one quick note about the simulation mode:
When you try to connect to a module that needs ELM 327 and you don't have ELM 327 interface in Settings then you will get "Connection Failed! You need ELM327/OBDKey to connect this module... " message. Configuration of correct interface is required even in simulation mode (although it is actually not used).
Swiko
Post by Swiko »
yani wrote:Ok, one quick note about the simulation mode:
I have missed that, as settings disappeared when I've updated to latest version.
Now is working perfectly.
Sorry for bothering you :D.
Thank you!
