Good evening everyone,
Alfa 159 2.0l JTDM, I read all the good engine Carto, the graph also, I can get it reset faults.
But can not go in the service ...
Also, when I run test interface, "dialogue well" but said that the connection to Can not impossible as EML 1.3 +
Out on the site of Multiecuscan, it is well written EML 1.3 or higher??
Any ideas??
thank you ...
EML 1.5a
Re: EML 1.5a
The problem with most of the Chinese ELM 1.5 interfaces is that they actually have ELM software version 1.2 inside.
The requirement for ELM 1.3 or higher is for genuine ELM interfaces. The Chinese clones come in various versions (1.4a, 1.5, 1.5a, 2.0, 2.1) which are not related to the actual version of the copied ELM software.
Re: EML 1.5a
Hello All,
This is a gray metal box 1.5a writing.
After removal, the card is ELM327 1.2!!
There is there a possibility to upgrade.
if not, or can I get a real minimum 1.3 ELM327
Since we can not rely on tagging!
Thank you ...
Thank you ...
Re: EML 1.5a
The 1.2 on the PCB is just the version of the circuit board, not the ELM itself.lotjevdb wrote:Hello All,
Thank you ...
Try opening hyperterminal in windows (start > run > hypertrm)
- Start a new connection and choose to connect to the COM port it is installed on
- Set bits per second to 9600 and flow control to none, then click ok
- If it manages to connect to the interface and opens an empty text box, type "ATZ"
- The ELM327 chip will then return its internal software version
Re: EML 1.5a
Hello everyone,
I did exactly manipulation.
At the ATZ command, it responds:
ELM327 v1.5a
Soon
ELM327 v1.5a
Soon
Re: EML 1.5a
I have no doubt !
But here's the complete log Multiecuscan :
ANSWER: ATZ
ELM327 v1.5a
ELM327 v1.5a
ANSWER: ATE0
ANSWER: OK
ANSWER: OK
ANSWER: OK
ANSWER:?
ANSWER: OK
ANSWER: OK
ANSWER:?
ANSWER: OK
ANSWER: OK
ANSWER: OK>
ANSWER: OK
WARNING: This interface IS NOT compatible with ELM 327 1.3! Will not connect to Any CAN module.
The two commands that do not respond are:
ANSWER:?
ANSWER:?
Cordially
ANSWER: ATZ
ELM327 v1.5a
ELM327 v1.5a
ANSWER: ATE0
ANSWER: OK
ANSWER: OK
ANSWER: OK
ANSWER:?
ANSWER: OK
ANSWER: OK
ANSWER:?
ANSWER: OK
ANSWER: OK
ANSWER: OK>
ANSWER: OK
ANSWER:?
ANSWER:?
Cordially
Re: EML 1.5a
Hello everyone,
Welcome back to the sender!
Exchange with an ELM327 1.4.
All is OK now ...
See you soon, thank you
All is OK now ...
