147 1.6 Failed proxy after make windows anti-trap sensors.
bubu321
Post by bubu321 »
- I has error B1005/ B1006, not active windows anti-trap sensors.
- after doing windows anti-trap sensors procedure ( give complete signal ) must make proxy allignment.
- but procedure proxy alignment failed.
Engine
Bosch Motronic Me7.3.1 EOBD injection (1 lambda)
ISO Code: 7C 86 8A 80 61
Body
Marelli Body Computer
ISO Code: 40 83 89 80 A1
Dashboard
Service Interval Reset
ISO Code: 32 83 26 85 B5
Driver's Door (TRW)
ISO Code: 86 07 02 19 FD
Boot (TRW)
ISO Code: 07 07 02 19 FE
COMPLETED
- test inside of FES.
COMMAND: ATZ  RESPONSE:  ELM327 v1.4
COMMAND: ATI  RESPONSE: ATI ELM327 v1.4
COMMAND: ATE0 RESPONSE: ATE0 OK
COMMAND: ATL0 RESPONSE: OK
COMMAND: ATH0 RESPONSE: OK
COMMAND: ATSPC RESPONSE: OK
COMMAND: ATS0  RESPONSE: OK
COMMAND: ATCAF0  RESPONSE: OK
COMMAND: ATCFC0 RESPONSE: OK
COMMAND: ATCRA 7B0 RESPONSE: OK
COMMAND: ATSH 7B0 RESPONSE: OK
COMMAND: ATAT1 RESPONSE: OK
COMMAND: ATST41 RESPONSE: OK
COMMAND: ATBI  RESPONSE: OK
- try other interface ELM327 v.1.4, no good result.
- error log
  • WARNING: This vehicle is properly configured. PROXI Alignment is not needed!
    EXECUTING ADJUSTMENT...
    Windows' Anti-Trap Sensors
    COMPLETED
    PROXI Alignment Procedure
    Writing to module: Body Computer Node (NBC)SUCCESS!
    0
    0
    Writing to module: Dashboard Node (NQS)FAILED!
    Writing to module: Driver Door Node (NPG)SUCCESS!
    Writing to module: Boot Node (NVB)SUCCESS!
    Writing to module: Climate Control Node (NCL)SUCCESS!
    FAILED TO EXECUTE
- next problem, after exchange dashboard VDO no communication to this instruments.
- but proxy alignment not working.
  • Engine
    Body
    Other
    Driver's Door (TRW)
    Other
    Boot (TRW)
    COMPLETED
FESLog_1103310835_ALFA 147 1.6 TS 16V 105CV.txt
(2.45 KiB) Downloaded 81 times
Re: 147 1.6 Failed proxy after make windows anti-trap sensor
The PROXI function in 147 fails to configure the instrument cluster node.
This, however, is not a problem in your case as your instrument cluster does not need to be configured.
Please note that the automatic windows function will not work when anti-trap sensors don't work (or when you don't have anti-trap sensors at all).
bubu321
Post by bubu321 »
after exchange dashboard VDO no communication to this instruments by CAN.
- this is problem because VDO realise this
VDO ( MannesMan instrumental panel ) VDO Extra:
- inspection service value
- next service reset
- Light setting corr.
- odometr km entry
- dashboard replacement
Hi bubu321
I have almost the same problems as you regarding anti-trap sensors.
I turned on the function and tested a little bit…
Windows were working but only sometimes.
Sometimes they stuck in the middle, sometimes they would work just fine and for a while... And then they stoped... :D
I guess that I do not have those sensors installed. :roll:
I got the same errors like you…
So I turned off the function and delete the errors and everything is back to normal! ;)
bubu321
Post by bubu321 »
@alfa156sarajevo
- and proxy alignment is working without error ?
( hm, AR 147 JTD )
- where is connector for this sensors.
- i will try connect 300 om, but don't know where is connectors.
p.s.
- must be between 1k2 - 1k9 and working.
- http://img585.imageshack.us/i/czujnikpoprawny.jpg/
The-Kevster
Post by The-Kevster »
bubu321 wrote:- and now it 's working.
- add emulator to anti-trap sensor socket.
Congratulations! Nice work.
Could you tell me what you did to emulate the anti-trap sensor and where I would find the socket? Currently both of my sensor voltages report 5v so I'm guess this isn't reporting correctly?
Thanks for your help!
bubu321 wrote:@alfa156sarajevo
( hm, AR 147 JTD )
p.s.
NO! :( The PROXI is not working in all "Nodes".
As you already know that PROXI functions always fails at the "Dash Node" (dashboard).
So I just click execute the PROXI function and that is it!
I have no idea where are these sensors and connectors are. Maybe they should be in doors!?!
As soon as I get some time I will remove door panels and will try to find it... :roll:
The-Kevster
No need to look in the doors. See here
viewtopic.php?f=4&t=1548&start=30#p5899
:D
