Serial-OBDII cable pinout
paskuale
Post by paskuale »
Hello boys,
I have one interface ELM 327 v1.2a USB (chinese clone) in metal box.
I have lost the serial DB9 <-> OBDII cable of interface !
Can anyone give me the pinout of this cable ?
I need to know each DB9 pin what pin represents in OBDII port.
Re: Serial-OBDII cable pinout
Here you go - see attachment
paskuale
Post by paskuale »
Thanks s130 for pinout.
In the center column are DB pin and in right column OBDII pin ?
Yes!
On the Left is the Gendan 16 pin OBD wiring to Canon 9 Pin.
On the Right is the Tekmate 16 pin OBD wiring to Canon 9 Pin.
I have both Gendan & Tekmate cables so recorded the witing of each in this combined chart.
Only difference between them is in the use of a single or double wire to handle the Ground connections.
paskuale
Post by paskuale »
Big Thanks to you s130 ! ;)
Tomorrow I try to make the cable and tell you the result.
Regards :)
paskuale
Post by paskuale »
Perfect :D
Many thanks ! ;)
