paskuale
Posts: 6 Joined: 11 Mar 2011, 16:07
Post
by paskuale » 11 Mar 2011, 16:16
Hello boys,
I have one interface ELM 327 v1.2a USB (chinese clone) in metal box.
I have lost the serial DB9 <-> OBDII cable of interface !
Can anyone give me the pinout of this cable ?
I need to know each DB9 pin what pin represents in OBDII port.
Posts: 1022 Joined: 20 Jan 2010, 10:07
Post
by s130 » 12 Mar 2011, 12:53
Here you go - see attachment
paskuale
Post
by paskuale » 12 Mar 2011, 15:01
Thanks s130 for pinout.
In the center column are DB pin and in right column OBDII pin ?
Post
by s130 » 12 Mar 2011, 18:01
Yes!
On the Left is the Gendan 16 pin OBD wiring to Canon 9 Pin.
On the Right is the Tekmate 16 pin OBD wiring to Canon 9 Pin.
I have both Gendan & Tekmate cables so recorded the witing of each in this combined chart.
Only difference between them is in the use of a single or double wire to handle the Ground connections.
paskuale
Post
by paskuale » 12 Mar 2011, 19:51
Big Thanks to you s130 !
Tomorrow I try to make the cable and tell you the result.
Regards
