Polish tranlation
tzok
Polish tranlation
Post by tzok »
I've recently seen a Polish translation of parameters and errors in v.2.1 - it was a nightmare not a translation in v.2.3 i a little bit better but still far from perfection... some parameters are really hard to guess what do they mean.
seth
Re: Polish tranlation
Post by seth »
So, why don't you make your, better translation?
I agree that current trans is poor, but better poor than no one, right? ;)
poziomka
Post by poziomka »
Poprawiłem błędy językowe i gramatykę. Uzupełniłem brakujące tłumaczenie.
New translation for 2.3.1
Polish.txt
Wersja 2.3.1
(12.47 KiB) Downloaded 530 times
Can other Polish people confirm that this translation is better than the one included in version 2.3.1?
If it is better then I will include this one in version 2.4
seth
Post by seth »
yani wrote:Can other Polish people confirm that this translation is better than the one included in version 2.3.1?
I do not know is it better, but I still see many grammatical and spelling errors. I can prepare my version if you want.
EDIT: I attached my translation and wait for feedback.
Polish.txt
(6.51 KiB) Downloaded 567 times
tzok
Post by tzok »
mg/i = milligram per injection - miligramy na wtrysk/dawkę (mg/wtr.)
rpm = revolutions per minute - obroty na minutę (obr./min)
SECURITY CODE = KOD ZABEZPIECZEŃ / KOD BEZPIECZEŃSTWA
Wydaje mi się też, że lepiej brzmiałoby "skasuj/wykasuj błędy" niż "wyczyść błędy", również lepiej by brzmiało "Wykryte zakłócenia" czy "Wykryto zakłócenia" niż "Zakłócenia wykryte".Tak samo "Zaznaczone do góry", powinno być raczej "Najpierw zaznaczone". W testach są "WARNING LIGHTS", w tłumaczeniu są to "ŚWIATŁA OSTRZEGAJĄCE", nie wiem czy chodzi o kontrolki na desce czy o światła awaryjne.
WARNING LIGHTS are MIL lamps on dashboard or external warning/emergency/hazard lights (blinkers)?
