Hello and greetings to all of you,
For over a week I'm trying to do a PROXI Alignment on my Peugeot Boxer (same model as the Fiat Ducato Typ 250) and getting really frustrated. I have tried 4 cheap Chinese OBD2 ELM327 devices and also removed the 120ohm resistor on one of them. Then I bought the expensive OBDLink CX, which didn't work on my computer and finally bought the OBDLink LX, which I am trying right now. I was able to connect all of them in MES, however, when trying to connect to "CAN Setup / PROXI Alginment Procedure (250)" (as well as to other modules), I get the error "Failed to connect to Body Computer (BCM)".
Depending on the module I try to connect, I also get the error message "ELM327 -> ECU Connection failed!". When testing the interfaced in MES Settings, everythink was ok (with all the devices).
I have a registered licence for MES and use the yellow adapter cable by the way.
Can anyone help me please? All I want is to disconnect the old radio in order to install a new one and the PROXI Alignment procedure keeps me stuck here...
Thank you in advance!
Test interface connection:
RESPONSE:
ELM327 v1.4b
ELM327 v1.4b
The cheap chinese devices had a speed rate of 38400 by the way, while the expensive OBDLINK LX (Bluetooth), only has 9600 (which I can't change):
Please connect the interface to a car!
Scanning ...
OBDLink / Vgate vLinker (USB/Bluetooth) / STN1155 v5.6.19 interface found at port COM12, speed 9600bps
COMPLETED
Best regards
Stefan
