can`t connect
carcon
can`t connect
Post by carcon »
Hi, i want to upgrade my old odometer (Ducato 250, 2017) to new one virtual from 21.
scan and reading at old one no problem, everything works,
but when i connect the new odomeeter to the car, i can not connect with Multiecuscan,
i try serveral Models, but comes errors like: Time out error, check cable + port, can`t connect to Body Computer.
somebody an idea ?
Re: can`t connect
Early 250 Ducato models only needed basic ELM support for the Instrument panel. Later models require adapter A3
250 Facelift and 290 model
Ducato (type 250) : Instrument Panel Marelli |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM
Ducato (type 250) Facelift : Instrument Panel Marelli |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM | A3
Ducato (type 290) : Instrument Panel Marelli |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELM | A3
MES will not prompt for adapter A3 if you select your earlier 250 model.
In MES select try selecting the 250 Facelift or 290 model.
carcon
Re: can`t connect
Post by carcon »
Hi, i done it like you describe, i try 250 +290 facelift, ELM + Adapter A3, scan + connection + proxi no Problem when the old odometer
is connectected to the car, only when i connect the new odometer to the car i get the errors , no connection
Re: can`t connect
Sorry to hear this.
I must leave this to others now who are probably far more experienced than me in using MES with "out of normal configuration" operations and connections.
Re: can`t connect
Thinking about this I suspect that your vehicle does not have the wiring to support the later instrument panel.
Re: can`t connect
same cluster connectors don't mean pin out is the same on old and new clusters. check wiring diagrams.
seagoon2
Re: can`t connect
Post by seagoon2 »
carcon wrote: 18 Sep 2025, 08:56 Hi, i want to upgrade my old odometer (Ducato 250, 2017) to new one virtual from 21.
somebody an idea ?
U
Have you tried AI (chatGPT) you should find the answers your looking for I use it all the time and when it comes to Multiecuscan Its brilliant TRY IT
Regards Dave
carcon
Re: can`t connect
Post by carcon »
Have checked wire diagram, it`the same, AI i try also but nothing new that i don`t know,
have also tryed with ELM high speed Modus, when i run a scan it`reading Data when the new odomter is connected,
but comes only one error with the steering, connection to BC not possible
