Error on remote programming
m.a.l.f.a
Post by m.a.l.f.a »
Hello!
When I start to add the remote control procedure in MES in my Musa I have to type in the electronic code as first step.
When I do this the MESsays error.
I tried several times always error.
I asked a dealer to print out my electronic code to check if the code card I got with my car is correct, it is
What do you need so you can help me?
Interestingly I see a success for the code in the log but the MES knterface had an error and the procedure was stopped.
Any ideas?
Multiecuscan 4.7R3)
27.04.2025 14:22:42
Lancia Musa 1.4 16V
Body Computer Marelli (843FL) MY06
ECU ISO code: 40 83 45 08 E5
FIAT drawing number: 51835532
Hardware number: BC848S.0100
Hardware version: 01
Software number: 04440001802
Software version: 0502
Homologation number: 000101
ECU programming date: 05/27/2009
EXECUTING ADJUSTMENT...
Remote control programming
SECURITY CODE
SUCCESS
Re: Error on remote programming
maybe BCM was replaced some time ago hence PIN from card isn't right.
m.a.l.f.a
Post by m.a.l.f.a »
Would the program then say
SECURITY CODE
SUCCESS
How can the code be read or tested otherwise?
m.a.l.f.a wrote: 05 May 2025, 17:27 Would the program then say
SECURITY CODE
SUCCESS
try entering any wrong PIN and see what happens.
PIN can be read with specialized tools through OBD or with programmer from body ECU. usually those who make keys also have equipment.
m.a.l.f.a
Post by m.a.l.f.a »
Today I tried again.
I used the indicator procedure to verify the code, it works there. When I enter the code I have succes and can activate or deactivate the indicators command.
On the remote programming:
When I enter a wrong code I get the proper error message.
When I enter the correct code I get: unexpected error
The log says security code success...
Any ideas?
