Recently I swaped the old uconnect 5 inch unit with the newer Uconnect 7 (EMEA DAB GPS). Odo started blinking and after some failed proxi alignment procedures using MES and my obdlink sx scanner, my mechanic offered to perform it using his professional witech 2 tool. Everything worked fine. However witech does not allow any feature enable/disable. So I tried again using MES. Proxi was extended by witech to 250 bytes with the last 106 bytes all set to 00.
I tried the following configurations:
1. byte 148=05, 157=01, 160=01
2. byte 157=01, 161=03, 171=01, 235=80
In both cases proxi alignment succeeded but any of these configurations did not work for me.
I have also swapped the usb module with the 2xusb one that came with the newer head unit.
What am I doing wrong?
I also tried to enable comfort windows with no luck (not at the same time with all the above) (I know that's irrelevant but I mention it for the record).
Thanks in advance.
500x Uconnect 7 retrofit CANT enable CarPlay
abarthmultijet
Re: 500x Uconnect 7 retrofit CANT enable CarPlay
Can you upload your original proxy code?
Witech is indeed not useable to perform modifications.
Sorry for the misinformation, actually witech has made more modifications than just extending the proxi.
Factory proxy:
Witech proxy:
Is there any possibility that the problem is in the usb module?
The usb module that came with the unit is this one:
However I read somewhere that this module is not compatible with carplay and that I need this one:
Unfortunately there is no android phone available right now in order to test android auto too.
Factory proxy:
33 38 33 33 34 30 34 39 35 32 39 4F 55 54 50 55 54 2D 53 49 54 20 15 01 24 4F 05 20 05 10 00 00 00 02 00 00 00 00 00 00 00 4F 04 20 05 10 00 00 00 02 00 00 00 00 00 00 00 D1 FA 0C 01 AC 81 07 E2 20 27 09 07 40 10 10 03 A3 1E 24 92 01 35 73 14 01 4F 03 34 00 B3 A8 02 46 03 07 00 8E 00 11 56 00 00 10 01 00 05 02 54 91 8C 02 A5 40 42 00 01 8A 12 3D 40 00 01 03 C5 00 D5 44 10 00 00 49 01 81 12 73 42 00 00 00 13 AA 97 71 20 80 80 85 00Code: Select all
33 38 33 33 34 30 33 31 36 37 32 4F 55 54 50 55 54 2D 53 49 54 20 15 03 04 4F 04 00 04 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 04 10 00 00 00 00 00 00 00 00 00 00 00 D1 FA 0C 02 AC 02 07 E2 50 27 09 07 42 10 00 03 A3 28 54 91 01 35 73 14 01 4F 03 34 00 B3 A8 01 49 03 07 00 A2 00 0D FB 00 00 10 01 00 05 03 54 FA 50 02 AD 40 42 00 01 8A 12 3D 40 00 01 03 C1 00 81 44 10 00 00 49 02 81 12 52 42 00 00 00 8B AA 95 71 20 80 80 85 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00The usb module that came with the unit is this one:
Any thoughts on this?
abarthmultijet
I have a proxy of an 2020 500x with an 7 inch uconnect. You can try to make it work. Currently a bit busy to sort it out.
33 38 33 33 34 31 33 32 32 38 39 4F 55 54 50 55 54 2D 53 49 54 20 19 04 03 4F 0C 40 45 10 00 19 02 02 00 00 00 00 00 00 00 4F 0C 40 45 10 00 19 02 02 00 00 00 00 00 00 00 D1 EA 35 01 AD 82 08 02 C0 27 09 07 45 10 10 01 A3 1E 00 92 01 35 73 14 01 4F 03 B4 1B A3 88 00 5F 03 05 00 92 80 11 56 00 00 18 03 00 21 10 54 EB 07 06 A5 00 52 00 05 8A 10 3D 40 00 03 03 C5 00 D5 24 13 0A 00 49 00 81 14 7B 42 05 00 00 BB A2 99 71 20 80 22 C2 11 20 23 09 00 00 00 00 00 00 00 00 01 0E C0 01 03 82 00 01 00 00 02 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
there are few "have to do" things for keep carplay working...
- first is radio support because some models doesnt have it - check partnumber in eper
- second is USB box with carplay support
- third is after newest firmware update it needs newest USB box (because of radio and RVC stucking)
