Fiat Ducato Remove Driver Assistant System Node (DASM)
Posted: 08 Jan 2025, 12:35
by linknet
I have a 2022 Fiat Ducato and it has the Driver Assistant System Node (DASM) which was purchased as an extra on the new vehicle. This module has given many problems which, as yet, Fiat have been unable to solve.
I would like to remove it using MultiEcuScan. I would appreciate any advice on this.
If I run a proxi alignment and disable that module would that work or would I have to physically remove the module which I understand to be integrated within the HALF Lane Sensing Camera?
Re: Fiat Ducato Remove Driver Assistant System Node (DASM)
Posted: 18 Jun 2025, 23:16
by kevin2008
yes, very good question. you have test ?
