Fiat Ducato Remove Driver Assistant System Node (DASM)
linknet
Post by linknet »
I have a 2022 Fiat Ducato and it has the Driver Assistant System Node (DASM) which was purchased as an extra on the new vehicle. This module has given many problems which, as yet, Fiat have been unable to solve.
I would like to remove it using MultiEcuScan. I would appreciate any advice on this.
If I run a proxi alignment and disable that module would that work or would I have to physically remove the module which I understand to be integrated within the HALF Lane Sensing Camera?
kevin2008
Re: Fiat Ducato Remove Driver Assistant System Node (DASM)
Post by kevin2008 »
yes, very good question. you have test ?
didi_du_93000
Post by didi_du_93000 »
I have Fiat Tipo MK2.
I have removed the DASM from node.
Proxy alig is ok, DASM is disconnected. and have put in prox adaptation the standar regulator (foriginal value is ACC).
Now i have ESP light on dash, and some message from ABS/ESP too.
Any change to resolve the problem? need to code/adapt ABS modul?
Regards,
didi_du_93000 wrote: 04 Sep 2025, 06:48 Hello,
Regards,
try performing lateral/longitudinal sensor calibration in ABS ECU. see if it will solve you problem.
