Oil Change Parameters
mjb_i
Post by mjb_i »
I successfully installed a SGW bypass in order to execute an oil change update. I went to the Engine adjustments and followed the instructions to perform the oil change reset. With the SGW bypass, it executed properly. I also performed the other items including the self adaptation parameters reset. I turned off the car, as instructed, waited a minute, then went back in. When in parameters, the oil change counter, degradation and last oil change did not change from zero. Why is that? I repeated the sequence. Still no change in those parameters, although I advanced the miles to next oil change. How do I reset miles to next oil change, and also get the other parameters to register?
This is for a 2023 Alfa Romeo Giulia Quadrifoglio.
HeMaN
Re: Oil Change Parameters
Post by HeMaN »
Is the oil change counter at zero?
mjb_i
Post by mjb_i »
Pardon the late response. Yes, the counter is at zero. I did the reset function more than once, so the mileage notification advanced each time, but the counter did not. I waited until I was in for inspection to do the service reset. That worked fine. The oil counter and mileage are the only ones not registering correctly.
HeMaN
Post by HeMaN »
If the counter has reached zero it will indeed not show anything snymore for the oil change interval. I think they believe 9 oil changes are enough for the lifetime of the car :D :D
When it is not zero, doing a proxy alignment resets it to 10 again. I heard some people have succes with resetting it even though it already reached zero, others mention it will not reset anymore.
Curious what your experience will be
