Hello i have used the last fiat ecu scan 2.2.1 and used ELM327 v 1.4, I can connect to the vehicle and i have choose the correct iso code ( BOSCHEDC16C39 CF4) my vehicle is (alfa 147 1.9 120hp jtdm).
The problem is i cant see lot's of parameters (Odometers, max rpm, particle filter and other) about 20 parameters cant read.
RESPONSE: ATZ
ELM327 v1.4
RESPONSE:
ELM327 v1.4
Can't read lots of parameters
alfa147jtdm2008
Re: Can't read lots of parameters
Does it show correct readings on the Info window?
Because there is a problem with the ELM interface which I already fixed in next version. It does not always read the ISO code, and might show empty/invalid ISO code as well as invalid reading for the other parameters. It is reported only on EDC16 ECUs.
If it is the same problem the you have to wait a week till the next release, or you can use VagCom interface.
alfa147jtdm2008
Ok thanks yani
. Yes i think it's show a correct reading.
alfa147jtdm2008
HI i have the same problem
i can't read odometer and other parameters.
- Sans titfggtgtgtgfffre.jpg (307.43 KiB) Viewed 6888 times
- Sans titre.jpg (190.03 KiB) Viewed 6889 times
147jtdm8v120
I also have this problem (version 2.4.1)
alfa147jtdm2008
Hi i have test the new version 2.5 and i have always the same problem. I can't read lots of parameters
. I have elm327 1.4 link.
Please help me Yani
Please help me Yani
sa80libero
[Quote = "alfa147jtdm2008"] Ciao ho testare la Nuova versione 2.5 e ho semper Lo Stesso Problema. Non Riesco a leggere delle Nazioni Unite sacco di Parametri: cry:. Ho ELM327 1,4 link.
Please help me Yani:) [/ quote]
