Hello Fefe
Make please times a test in settings / interfaces / Test
And adjust the screen here
To read the Guilettas as described yellow Adapter
and for the Stilo still the green adapter
And you need for Airbag a KKL Interface
legone
Post by legone »
I am the happy owner of an Alfa 159 2.2 JTS.
I bought a ELM327 Wifi. I can only connect to the engine module for the moment.
I would be able to reset my Service indicator. And to do that I'd like to connect to the Service module.
I bet it means that I have to remove a resistor.
There are so many board layouts that I did not manage to guess which one.
Full res here: http://www.googledrive.com/host/0B7dgk3 ... lZ0ai1pN2c
I have a suspicion on the 121 resistor at the bottom and center of the image.
Could you be so kind to confirm thats the one to remove?
Best regards
Fabrice
Hello Fabrice
Yes this is the bridge resistor that must be removed !!
Could you please have a link of this interface here Set
and a screen of the test in MES / Settings / Interfaces ??
Because there are more and more new ELM interface on the market
who can not work with MES.
Meanwhile, it is difficult to suggest interface.
zapdus
Post by zapdus »
Hello, i have a 2009 alfa romeu mito and i can connect with engine, abs, etc (high speed can)
But i can't connect to low speed can
I think i most remove the bridge resistor
But i can't find where it is
Can any1 help me?
Here is my PCB
Thank you!
It is a ELM327 USB V1.5
This interface we had been there several times
in red frame the bridges Resistor is highlighted
6126927B markiert.jpg (127.37 KiB) Viewed 10261 times
legone
Post by legone »
Alfaeddy wrote:Hello Fabrice
First, thanks for the answer !
I bought the interface here:
http://www.dx.com/p/elm327-obd-wi-fi-au ... lue-321243
For the moment I can tell you that MES reports that it connects successfully to the ELM. I can connect to the Engine module and read / clear the errors. Nothing else though (with the resistor).
I can also connect with my iPhone using some free OBD II utilities.
I'll make a snapshot of MES as soon as I try it again with the resistor removed (probably next week end).
And I ll also keep you posted if it works fine.
Best regards
Fabrice
Herpez
Post by Herpez »
My elm327 is broken after i tried to fix it :(
Can someone recommend me a fully working elm327 device with bluetooth whithout the needed to a fix?
Aliendex
Post by Aliendex »
Hello guys,
I'm using a cheap chinese ELM 327 which doesn't work with MultiEcuScan even when it was original (with the resistor), this is the module:
As you can see i've already removed resistor R34 (120 Ohm) but i have the same error in MultiEcuScan.
With Torque, ScanMaster and PCMSCAn it's working fine.
RESPONSE: ATZ
ELM327 v2.1
ELM327 v2.1
RESPONSE: ?
RESPONSE: ?
RESPONSE: ?
As you can see in the test screen, this is a software on the chip
V2.1
And the v2.1 does not run with MES or AlfaOBD
Why this is so I can not say
This would require more Yani can say.
Aliendex
Post by Aliendex »
V2.1
Thank you Eddy!!
In this case i will continue to use this module only with the software mentioned before (Torque, ScanMaster, PCMSCAN)
What version of elm 327 should I buy to make sure it's working correctly?
I have a Fiat Grande Punto 1.3 Mjet 66kW/90HP (2007) with a Marelli 6F3
P.s.: Do i need to re-solder R34 or I leave the module modified?
