I added the cruise control switch and tried to activate it with proxi alignment, but it does'nt work.
I tried to do the proxi alignment few times, but nothing changed. In dashboard i'm not able to activate CC light.
Please find my logs below:
CAN CONFIGURATION DATA:
6F 00 00 04 00 00 00 00 6F 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00
33 38 31 39 39 30 30 30 35 31 31 4F 55 54 50 55 54 2D 4A 49 54 20 05 10 05 6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 C1 00 03 07 62 00 2A 10 23 00 00 06 00 00 00 84 06 01 02 00 00 00 00 00 3A 51 05 0C 0D 00 00 00 00 00 00 00 00 11 09 60
CURRENTLY CONFIGURED CAN MODULES:
Body Computer Node (NBC)
Engine Control Node (NCM)
Electric Steering Node (NGE)
Dashboard Node (NQS)
Receiver Radio (NRR)
Brake System Node (NFR)
Airbag Node (NAB)
CURRENTLY AVAILABLE CAN MODULES:
Airbag Node (NAB)
CAN MODULES THAT REQUIRE EOL PROGRAMMING:
Airbag Node (NAB)
07.09.2011 21:49:25
CONNECTED TO:
FIAT GRANDE PUNTO 1.3 MJET 16V
CURRENTLY CONFIGURED CAN MODULES::
Body Computer Node (NBC):
Engine Control Node (NCM):
Electric Steering Node (NGE):
Dashboard Node (NQS):
Receiver Radio (NRR):
Brake System Node (NFR):
Airbag Node (NAB):
CURRENTLY AVAILABLE CAN MODULES::
Airbag Node (NAB):
CAN MODULES THAT REQUIRE EOL PROGRAMMING::
Airbag Node (NAB):
EXECUTING ADJUSTMENT...
Cruise control
Old value: Disabled
New value: Enabled
COMPLETED
Writing to module: Dashboard Node (NQS) FAILED! - Request out of range error
Writing to module: Airbag Node (NAB) SUCCESS!
FAILED TO EXECUTE
Any Ideas?
CC is working fine, CC indicator in dashboard still does not work and the flashing odometer is also don't like.
When I open proxi alignment, get the message "no proxi alignment necessary".
