Problem CC activation at Grande Punto 1.3MJET
holbli
Post by holbli »
Hello together!
I added the cruise control switch and tried to activate it with proxi alignment, but it does'nt work.
I tried to do the proxi alignment few times, but nothing changed. In dashboard i'm not able to activate CC light.
Please find my logs below:
CAN CONFIGURATION DATA:
6F 00 00 04 00 00 00 00 6F 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00
33 38 31 39 39 30 30 30 35 31 31 4F 55 54 50 55 54 2D 4A 49 54 20 05 10 05 6F 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 C1 00 03 07 62 00 2A 10 23 00 00 06 00 00 00 84 06 01 02 00 00 00 00 00 3A 51 05 0C 0D 00 00 00 00 00 00 00 00 11 09 60
Body Computer Node (NBC)
Engine Control Node (NCM)
Electric Steering Node (NGE)
Dashboard Node (NQS)
Receiver Radio (NRR)
Brake System Node (NFR)
Airbag Node (NAB)
Airbag Node (NAB)
Airbag Node (NAB)
07.09.2011 21:49:25
CONNECTED TO:
FIAT GRANDE PUNTO 1.3 MJET 16V
Body Computer Node (NBC):
Engine Control Node (NCM):
Electric Steering Node (NGE):
Dashboard Node (NQS):
Receiver Radio (NRR):
Brake System Node (NFR):
Airbag Node (NAB):
Airbag Node (NAB):
Airbag Node (NAB):
EXECUTING ADJUSTMENT...
Cruise control
Old value: Disabled
New value: Enabled
COMPLETED
Writing to module: Dashboard Node (NQS) FAILED! - Request out of range error
Writing to module: Airbag Node (NAB) SUCCESS!
FAILED TO EXECUTE
Any Ideas? :cry:
CC is working fine, CC indicator in dashboard still does not work and the flashing odometer is also don't like.
When I open proxi alignment, get the message "no proxi alignment necessary".
fiatbravoemotion
Re: Problem CC activation at Grande Punto 1.3MJET
Post by fiatbravoemotion »
There is no led on your dashboard. It's empty place to solder it. There is no Cruise Control at dashboard's eeprom. Only one way is replace dashboard from highest version of car. I have this led on my GP 1.3 90 HP Sport 2006. But I don't have a car with this led in versions like Active and Dynamic.
This information about it "out of range" is confirming this.
holbli
Post by holbli »
Thank for this info. So there is also no option to avoid the flashing odometer indicating proxi alignment request?
fiatbravoemotion
Try Disable CC, turn switch to OFF position and get Proxi.Then Key off, wait 60 seconds or better disconnect Ground from battery. Check if flashing.
Try Enable CC without ON on switch. Key off, wait 60 seconds or disconnect Ground. Check if odometer is blinking. It can do after 5, 10 seconds. After minute try turn ON on CC switch. Close doors in all Proxi procedure to don't get any infos on display like Door open... Check if blinking.
I don't have situation, that odometer is blinking ...
Give me a VIN.
holbli
Post by holbli »
Without changing anything surprisingly this morning the odometer wasn't blinking anymore... :D
If you wait long enough, you'll catch something.
fiatbravoemotion
Very good :) Check battery in your car. Very often discharged battery make flashing odometer ...
taki--jeden
Post by taki--jeden »
I had the same issue with Dashboard Proxi, but all is working great!
Now when I changed dashboard to higher version (with cc light) Proxi didn't report any issues.
