Multiecuscan 3.1.x Language Files
tzok
Post by tzok »
Polish GUI translation - updated to FES version 3.1.1
P.S.
I have no idea who did the current Polish message file translation but it is totally screwed up, although it has better descriptions for gearbox errors - while English version has only "Gear Ratio (2)" the polish file has "Kontrola przelozenia pierwszego biegu".
I'll try to prepare a new one, based only on current English file.
Polish.txt
(12.44 KiB) Downloaded 507 times
tzok
Re: Multiecuscan 3.1.x Language Files
Post by tzok »
Does anyone know for sure what does mean the term "a monte"/"a valle" in correlation with O2 Sensor in Italian?
Sonda lambda 1 a monte (massa)
Segnale lambda 2 a monte (sbandata)
Is it above/below catalogue value or it describes the location of the lambda probe - above (before) or below (after) the catalytic converter?
And what are these valves:
Valvola di scarico posteriore SX (Rear left drain valve)
Valvola di carico post.SX (Rear left load valve)
tzok
Post by tzok »
Corrected polish.txt and updated to v.3.1.1 and completely rewritten polish.dat.
Polish.dat.txt
Please remove the .txt suffix prior to use this translation.
(181.82 KiB) Downloaded 461 times
Polish.txt
(12.44 KiB) Downloaded 441 times
tzok
Post by tzok »
Next doubt:
Pressione carburante (regolatore uscita pompa alta pressione o flauto)
Pressione carburante (regolatore ingresso pompa alta Pressione e flauto)
What are they about?
Fuel pressure (regulator output, high pressure pump or ???)
Fuel pressure (regulator input, high pressure pump and ???)
Flauto is the flute but I see no sense...
Next:
Interruttore leva 1
This is sth. about gerbox - Is this Gear 2 selector lever?
snorky
Post by snorky »
Hi wonder if you can also enter the Italian language in the yellow box multiecuscan ... thanks
Multiecuscan registrato
Multiecuscan Mobile 1.0.1 su Samsung Omnia i900
tzok
Post by tzok »
Content of the "yellow boxes" will remain in English.
snorky
Post by snorky »
You can not do anything for the Italian
tzok
Post by tzok »
FES v.3.3 POLISH DATA
Polish.zip
(33.2 KiB) Downloaded 395 times
