Unfortunately I can not see in the list of vehicles with which interface and which pin the xenon headlights is read.
Is needed in the list, only the adapter from A1 (green).
So I think that it is not read via the CAN bus.
Can someone help me?
Thanks and regards
Eddy
Which pin interface and the xenon headlights will be read?
Re: Which pin interface and the xenon headlights will be rea
You need to connect to pin 12 for the Xenon module.
Hi Yani
Thanks for your quick response.
It is safe to read only with a ELM interface?
Greetings
Eddy
Greetings
Eddy
You can read it with any interface - KKL, ELM, OBDKey.Alfaeddy wrote:It is safe to read only with a ELM interface?
However, if you are using KKL (VagCom) interface you will probably have to set "KWP2000 Timings" (in Settings) to "Default".
In the "Supported vehicles" list, all xenon projectors interfaces is specified only as "A1", without any other type. Can you correct this, please?
Yes, I will correct it...dallas140cv wrote:In the "Supported vehicles" list, all xenon projectors interfaces is specified only as "A1", without any other type. Can you correct this, please?
yani wrote:You can read it with any interface - KKL, ELM, OBDKey.Alfaeddy wrote:It is safe to read only with a ELM interface?
Thank´s for you
Greetings
Eddy
