proxy alignment for Panda does not work
Abraa
Post by Abraa »
Hi Yani,
Just bought elm327 v1.4 and registered to FES to do proxy for my gf Panda 1.1. Reason is I added new instrument cluster (with revs) and temp reader in mirror and the milage is blinking. Done a test in FES for my elm and it sees it alright with good speed, but whenever I connect to it as punto 99 1.2 or punto 03 1.2 it sees it all but can't finish proxy alignment. Here's the log:
Odczyt danych konfiguracyjnych CAN ...
CAN CONFIGURATION DATA:
00 00 00 0F 00 00 00 0F 00 00 00 0C 00 00 00 08 00 00 00 00
00 00 00 0F 00 00 00 09 00 00 00 0F 00 00 00 09 00 00 00 01
33 32 31 36 39 30 30 30 31 38 35 4F 55 54 50 55 54 4A 49 54 20 20 03 09 25 0F 00 00 00 09 00 00 00 10 00 00 00 00 01 14 00 00 00 04 06 01 00 00 00 00 00 00 10 00 00
OBECNIE SKONFIGUROWANE MODUŁY CAN:
Body Computer (NBC)
Kontrola Silnika (NCM)
Elektr. przekl. kierown. (NGE)
Tablica Przyrzadow (NQS)
OBECNIE DOSTĘPNE MODUŁY CAN:
Body Computer (NBC)
MODUŁY CAN KTÓRE WYMAGAJĄ PROGRAMOWANIA EOL:
Body Computer (NBC)
11-02-28 18:01:19
CONNECTED TO:
FIAT PUNTO '03 1.2 8V
OBECNIE SKONFIGUROWANE MODUŁY CAN::
Body Computer (NBC):
Kontrola Silnika (NCM):
Elektr. przekl. kierown. (NGE):
Tablica Przyrzadow (NQS):
OBECNIE DOSTĘPNE MODUŁY CAN::
MODUŁY CAN KTÓRE WYMAGAJĄ PROGRAMOWANIA EOL::
EXECUTING ADJUSTMENT...
Uklad ABS
GOTOWE
Procedura osiowania Proxi
Zapis danych konfiguracyjnych CAN ...
Zapis do modułu: Body Computer (NBC)UDANY!
Zapis do modułu: Tablica Przyrzadow (NQS)NIEUDANY!
WYKONANIE NIEUDANE
sorry it's polish. it looks like body comp connects fine but the cluster does not respond. Could you help me?
Fiat Panda 1.1 2004 & Fiat Punto 1.2 60 1998
olep
Re: proxy alignment for Panda does not work
Post by olep »
Hi Abraa, Yani,
I m really interested on what you 've done.
I made nearly same modifications like you. I added a connect+ nav on my panda + new instrument cluster + new rearmirrors with temp sensor on it.
Informations i have by now is that body computer must ask instrument panel to screen temperature
I don't know if proxi alignement could solve it but i think so.
@Yani,
In your list of support vehicules, you don't mention any CAN proxi alignement procedure for fiat Panda. Is it possible to use proxi procedure/commands for Stilo's or Punto's on Panda to force BC to update ?
@Abraa,
When you said you ve changed your instrument cluster, are you sure that you get the high level of instrument cluster (big screen on it with radio tags) ?
This one is the only one which is able to screen temperature. (temperature sensor is only available when you have automatic climate control unit)
See ya
Abraa
Post by Abraa »
yes, yes it's the right one... I also wrote down the serial number of it to check it against ePer, but I must have mistakenly hit wrong button on my phones touch screen cause I wrote down no 51759900 which ePer will not recognize. There is however 51759901 which should fit petrol model so probably my mistake. The reason I was checking is to see if the cluster wasn't out of diesel car or Punto, although I think Puntos have speedo on the right side instead. I'll try once more tonight if it won't rain, as I reinstaled drivers and set-up connection ports to 38400 baud in system management as I had this on 9600 there and 38400 in the FES. I hope this would work. I'll post the results if any. Yani, if you know anything, please post help anyway.
ps. I actually thinking if it's not due to cluster being from 2006 Panda, and car being 2004. Maybe some minor changes in cluster, and Body don't recognize it :/
16:22:
I tried it again, settings were right, but no success. Test in FES pass good, recognizes it as ELM 1.4a, but won't finish proxy. One thing I noticed is that when I click look for devices after it finds ELM on Com14 it complains that response is slow. Maybe here's what's going on? Help me please...
