Hi Yani,
Just bought elm327 v1.4 and registered to FES to do proxy for my gf Panda 1.1. Reason is I added new instrument cluster (with revs) and temp reader in mirror and the milage is blinking. Done a test in FES for my elm and it sees it alright with good speed, but whenever I connect to it as punto 99 1.2 or punto 03 1.2 it sees it all but can't finish proxy alignment. Here's the log:
Odczyt danych konfiguracyjnych CAN ...
CAN CONFIGURATION DATA:
00 00 00 0F 00 00 00 0F 00 00 00 0C 00 00 00 08 00 00 00 00
00 00 00 0F 00 00 00 09 00 00 00 0F 00 00 00 09 00 00 00 01
33 32 31 36 39 30 30 30 31 38 35 4F 55 54 50 55 54 4A 49 54 20 20 03 09 25 0F 00 00 00 09 00 00 00 10 00 00 00 00 01 14 00 00 00 04 06 01 00 00 00 00 00 00 10 00 00
OBECNIE SKONFIGUROWANE MODUŁY CAN:
Body Computer (NBC)
Kontrola Silnika (NCM)
Elektr. przekl. kierown. (NGE)
Tablica Przyrzadow (NQS)
OBECNIE DOSTĘPNE MODUŁY CAN:
Body Computer (NBC)
MODUŁY CAN KTÓRE WYMAGAJĄ PROGRAMOWANIA EOL:
Body Computer (NBC)
11-02-28 18:01:19
CONNECTED TO:
FIAT PUNTO '03 1.2 8V
OBECNIE SKONFIGUROWANE MODUŁY CAN::
Body Computer (NBC):
Kontrola Silnika (NCM):
Elektr. przekl. kierown. (NGE):
Tablica Przyrzadow (NQS):
OBECNIE DOSTĘPNE MODUŁY CAN::
MODUŁY CAN KTÓRE WYMAGAJĄ PROGRAMOWANIA EOL::
EXECUTING ADJUSTMENT...
Uklad ABS
GOTOWE
Procedura osiowania Proxi
Zapis danych konfiguracyjnych CAN ...
Zapis do modułu: Body Computer (NBC)UDANY!
Zapis do modułu: Tablica Przyrzadow (NQS)NIEUDANY!
WYKONANIE NIEUDANE
sorry it's polish. it looks like body comp connects fine but the cluster does not respond. Could you help me?
proxy alignment for Panda does not work
Fiat Panda 1.1 2004 & Fiat Punto 1.2 60 1998
Re: proxy alignment for Panda does not work
Hi Abraa, Yani,
I m really interested on what you 've done.
I made nearly same modifications like you. I added a connect+ nav on my panda + new instrument cluster + new rearmirrors with temp sensor on it.
Informations i have by now is that body computer must ask instrument panel to screen temperature
I don't know if proxi alignement could solve it but i think so.
@Yani,
In your list of support vehicules, you don't mention any CAN proxi alignement procedure for fiat Panda. Is it possible to use proxi procedure/commands for Stilo's or Punto's on Panda to force BC to update ?
@Abraa,
When you said you ve changed your instrument cluster, are you sure that you get the high level of instrument cluster (big screen on it with radio tags) ?
This one is the only one which is able to screen temperature. (temperature sensor is only available when you have automatic climate control unit)
See ya
@Yani,
@Abraa,
See ya
yes, yes it's the right one... I also wrote down the serial number of it to check it against ePer, but I must have mistakenly hit wrong button on my phones touch screen cause I wrote down no 51759900 which ePer will not recognize. There is however 51759901 which should fit petrol model so probably my mistake. The reason I was checking is to see if the cluster wasn't out of diesel car or Punto, although I think Puntos have speedo on the right side instead. I'll try once more tonight if it won't rain, as I reinstaled drivers and set-up connection ports to 38400 baud in system management as I had this on 9600 there and 38400 in the FES. I hope this would work. I'll post the results if any. Yani, if you know anything, please post help anyway.
ps. I actually thinking if it's not due to cluster being from 2006 Panda, and car being 2004. Maybe some minor changes in cluster, and Body don't recognize it :/
16:22:
I tried it again, settings were right, but no success. Test in FES pass good, recognizes it as ELM 1.4a, but won't finish proxy. One thing I noticed is that when I click look for devices after it finds ELM on Com14 it complains that response is slow. Maybe here's what's going on? Help me please...
16:22:
