Hello, all.
I would like to know if I can use this software with a 1995 Fiat Tempra i.e. 8v. It has the 3-pin inline connector behind the glovebox. What cable should I buy/make?
Thanks,
Mariano
Argentina
1995 Fiat Tempra i.e. 8v (made in Brazil)
Re: 1995 Fiat Tempra i.e. 8v (made in Brazil)
HI Friend, I am Brazilian, multiecuscan, works on all Fiat (fire) from 2001 to 2011, have tested, and the palio 49fb, but does not work in any other older.
Thank you very much, Adao (Muito obrigado, Adao).
Do you know if there's any software that I can use, or should I get a handheld unit with the proper cable, instead?
Best regards,
Mariano
Buenos Aires, Argentina
Best regards,
Mariano
OI Mariano, ja procurei muito, mas não existe softwer, para fiat , antigos, na internete, e lamentavel.
