1995 Fiat Tempra i.e. 8v (made in Brazil)
mlreta
Post by mlreta »
Hello, all.
I would like to know if I can use this software with a 1995 Fiat Tempra i.e. 8v. It has the 3-pin inline connector behind the glovebox. What cable should I buy/make?
Thanks,
Mariano
Argentina
adão carlos vieira
Re: 1995 Fiat Tempra i.e. 8v (made in Brazil)
Post by adão carlos vieira »
HI Friend, I am Brazilian, multiecuscan, works on all Fiat (fire) from 2001 to 2011, have tested, and the palio 49fb, but does not work in any other older.
mlreta
Post by mlreta »
Thank you very much, Adao (Muito obrigado, Adao).
Do you know if there's any software that I can use, or should I get a handheld unit with the proper cable, instead?
Best regards,
Mariano
Buenos Aires, Argentina
adão carlos vieira
OI Mariano, ja procurei muito, mas não existe softwer, para fiat , antigos, na internete, e lamentavel.
