Airbag ECU Error Code for a 1999 Alfa 156 2.0 TS
uranium235
Post by uranium235 »
I use a mod USB VAG cable connected to my 156.
got a Airbag error. try to remove it but failed.
anyone know what is this error code mean?
thanks
Error code for airbag ECU
leopard
Re: Airbag ECU Error Code for a 1999 Alfa 156 2.0 TS
Post by leopard »
Try off the connector on the computer AIRBAG, contact spray to clean all the connectors and then try to undo the mistake.
PS. Before this operation remove the negative pole of the battery.
And if this fails the only remaining programming eeproma airbag
or replacement airbag computer.
