I released version 2.6.1 today. It is a release that fixes a number of problems from version 2.6.
- Fixed the problems with Grande Punto, 500, MITO, Punto Evo support. It was not working with some ELM interfaces.
- Fixed a few problems in PROXI Alignment (CAN Setup) Procedure. It was working only in english and it failed on some vehicles
- Added CAN Info function for Grande Punto, 500, MITO, Punto Evo.
- Fixed a problem with VagCom interfaces. This problem was caused by the speed improvements in version 2.6.
						Multiecuscan 2.6.1 RELEASED!
				sa80libero
Re: Multiecuscan 2.6.1 RELEASED!
adesso dovrebbe funzionare sulle grande punto, grandepunto evo ecc?
Now it should work great on point, etc. grandepunto evo?
yes but to work fine with service interval reset with some elm interface you need to move pin 6 &14 to 1 & 9...but i don't know how to do..
When you say -...not working with some elm 327 interface, you mean the fake that need capacitor-resistor soldering or you mean other?
Thanks.
						Thanks.
more info you can find here: viewtopic.php?f=6&t=1692&start=30cicus wrote:yes but to work fine with service interval reset with some elm interface you need to move pin 6 &14 to 1 & 9...but i don't know how to do..
to find this topic just go to: Board index ‹ General ‹ Multiecuscan 2.6 RELEASED!
