Hello:
Very good your work, thanks.
It's possible translate softwate to spanish language ???
I may help you with all translations, if you send text file, I translate all for you for free of course.
About CAN bus feature that you advertise that will add in new versions:
Which interface will may use to work with CAN bus and your software ???
Current VAG KL or VAG KKL do not support CAN bus, only K line.
It's possible you do it compatible with ELM327 chip, that support CAN bus ??
Do not know another universal interface that may support CAN bus, because of VAg-COM CAN bus interfaces only work with VAG-COM software,because of it use special processor to work only with VAG-COM.
Kind Regards
Spanish translations and CAN bus
Re: Spanish translations and CAN bus
Thanks for links about CAN bus interfaces.
What do you think about translate software to spanish language ?
I may do all translations for you, so you may make software multilingue, or at least english-spanish.
Regards.
Regards.
I have not decided about the CAN interface yet. I will probably implement support for ELM327 because it is common and cheap.
I have no plans for multilingual support so far.
Ok, thanks yani.
I think it is a good option ELM327, very good chip, support most of protocols, all CAN bus variants, easy to manage with AT commands.
About translations, if you want do it, I may make all spanish translations for you.
Regards
Regards
ELM327 support
Hi yani,
I'm looking forward the ELM327 support! (I have an ELM327 multiprotocol interface, but it doesn't work with your soft yet.)
Can you to tell me a date (approx.) to beginning support of this interface?
Joseph.
Joseph.
