Fiat New Croma - power steering
gibon2000
Post by gibon2000 »
Recently I have a problem with power steering in my Fiat Croma 2006. I wanted to connect to power steering pump through K-line using FES but it doesn't support my car. I have pin 1, 3, 7 connected together in VAG plug and I tried to do it by using Fiat Idea settings (as I remember...) but nothing happened - no connection.
I also checked electric schematics in eLearn program and I noticed that in Croma power steering K-line goes from connector C to main computer M001and there can be diagnosed on pin #12. I also tried that but nothing happened...
Or my power pump is completely dead (I have no power steering at all, sometimes red sign of steering wheel blinks) or I do something wrong with hard/software?
Can you help how to connect to power steering? I upload attachments with some schematics.
Power steering electric schema Fiat Croma (194)
Locations of elements
Re: Fiat New Croma - power steering
gibon2000 wrote:... I have pin 1, 3, 7 connected together in VAG plug and I tried to do it by using Fiat Idea settings (as I remember...) but nothing happened - no connection...
As I can remember you have to solder a short wire between pins 1-7-9 of your interface's OBD connector in order to connect to ABS and Power steering ECUs NOT a pins 1-3-7!!!
gibon2000
Post by gibon2000 »
Small mistake: connected pins are 1-7-9. I didn't connect with pin #3 (airbags). But still no answer from ECU (when #12 is connected to #7 - also).
Post by s130 »
OK.
I have a Croma 05 so I'll check myself when I get a chance, probably not till Friday/this weekend.
I'll try with both VAG and Elm interfaces.
Also gives me an excuse to check my Gendan patch cables.
Post by s130 »
s130 wrote:OK.
OK.
Have tried both VAG and Elm and NO Power Steering listed. SCAN reports some unsupported units/ISO codes but no ability to connect.
Looks like you'll have to wait till Yani supports the power steering unit.
Sorry.
gibon2000
Post by gibon2000 »
Thanks for quick response 8-)
And now all in Yani's hands :?
The support for FIat Croma power steering is already implemented in next version. You have to wait 10-15 days for its release.
gibon2000
Post by gibon2000 »
Thanks Yani! Do I need to modify my VAG cable? Connected pins 1-7-9 will be OK?
alfiat
Post by alfiat »
Thank you Yani for this new improvment.
Regards,
Alfiat
alfiat
Post by alfiat »
Yani,
I already did the update from 2.4 registered to 2.5 and went to my father Croma 07 plate in order to connect to the faulty power steering.
When I try to connect to steering it gives me fault connection between ELM and ECU.
I have the ELM modified in terms of pins 1, 7 and 9 but I think that for this car the steering is in the CAN network.
I connect to the CAN network and everything was OK and on the network the steering is in the CAN network.
I sent to FES server the SCAN report.
Give some help on this.
Regards,
Alfiat
