Hello, I soldered pins 3,1,7,9. But I can not connect airbag
Immagine.Cosi place you tell me if I done something wrong
Thanks!
KKL Help!
KKL Help!
- 2.jpg (499.87 KiB) Viewed 6909 times
- 1.jpg (558.06 KiB) Viewed 6909 times
Re: KKL Help!
It is NOT recommended to connect all the pins together.
Pin 7 to 1 and 9 is OK BUT not to 3 at the same time.
7 to 1 and 9 is OK (ECU & ABS & EPS & Body) is OK
7 to 3 (ECU & airbags) is ok
Re: KKL Help!
I did as you say you but it works ...
How should we set the KKL?
Thanks!
Thanks!
Re: KKL Help!
Sorry I don't understand what you are actually asking.
Re: KKL Help!
How to set comport
Re: KKL Help!
Change the lattency from 16 to 2.
That's all.
And try to select the com 1.
It is better.
That's all.
It is better.
