Hello, I replaced the original Uconnect 5 (Fiat 330 VP2 ECE) in my Fiat 500 L (199) with a Uconnect 5 (Fiat 330 VP2 NAV ECE).
Everything works.
Both radios are from 2013 and have software version VP2_CO_13.00.74.00.
Only the odometer is flashing.
Both radios have the same HEX data stored.
Without NAV:
33 31 33 33 30 30 31 38 31 36 36 4F 55 54 50 55 54 2D 53 49 54 20 15 04 30 4F 04 00 05 10 00 00 00 09 04 00 05 10 00 00 00 A5 C7 71 07 8F 20 37 10 31 00 00 06 00 07 00 84 06 15 01 1E C0 00 35 01 35 41 0A 0C 0D 00 80 1E 43 00 00 00 00 35 00 81 03 10 11 16 00 8F 00 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 00 00 00 00 00 80 12 00 10 00 00 00 40 00 01 00 0F 00 00 49 00 01 00 00 00
With NAV:
Change NAV:
33 31 33 33 30 30 31 38 31 36 36 4F 55 54 50 55 54 2D 53 49 54 20 15 04 30 4F 04 00 05 10 00 00 00 09 04 00 05 10 00 00 00 A5 C7 71 07 8F 20 37 10 31 00 00 06 00 07 00 84 06 15 01 1E C0 00 35 01 35 41 0A 0C 0D 00 80 1E 43 00 00 00 00 35 00 81 03 10 11 16 00 8F 00 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 00 00 00 00 00 80 12 00 10 00 00 00 C7 00 01 00 0F 00 00 49 00 01 00 00 00
I changed the HEX of the navigation radio from 40 to C7 in byte 121.
I performed a proxy alignment.
The flashing odometer remains.
What did I do wrong?
Perhaps you can help?
Thank you very much.
Florian
Uconnect 5 (Fiat 330 VP2 NAV ECE) flashing odometer
abarthmultijet
Re: Uconnect 5 (Fiat 330 VP2 NAV ECE) flashing odometer
Do you get an error message during proxy allignment?
Good evening, yes, unfortunately. The proxy isn't working. The radio isn't registered with the vehicle. I'll try to insert the pictures here.
- IMG_5616.jpeg (4 MiB) Viewed 11726 times
- IMG_5615.jpeg (4.14 MiB) Viewed 11726 times
- IMG_5563.jpeg (4.23 MiB) Viewed 11726 times
- IMG_5619.jpeg (2.53 MiB) Viewed 11416 times
abarthmultijet
After a failed proxy you will see a button here: (see attached file)
Can you upload what you see then?
- aangepast multiecuscan .png (197.2 KiB) Viewed 11282 times
Hi there, bedankt.
I will perform the proxy alignment again, and if there is a notification with my MES version, I will post it here.
@ abarthmultijet
I think I know what you mean, the report. I completely overlooked it. I'm adding it now. Sorry I have so little experience.
Report1.pdf- (466.28 KiB) Downloaded 404 times
abarthmultijet
Change Byte 123 from 01 to 11
And let me know how it went.
abarthmultijet wrote: ↑27 Nov 2025, 19:13 Change Byte 123 from 01 to 11
And let me know how it went.![]()
Hartelijk dank abarthmultijet!
Dat was precies de juiste weg. Groeten aan de provincie Noord-Brabant.
