So,
does it work only on 1.2 version?
Because i have the 1.3a clone that works great.
It seems to be the same of plastic one in your pictures....
I use a couple of softwares where i can choose bps rate and if i choose an higher value instead of 9600 it still works fine.
But i have an application that use elm-device values and it always get 9600bps.
Could i try to mod my device and see what happens....
just to clear it out...
what does this pictures mean?
download/file.php?id=193
have i to bridge pins marked on green?
thank you very much.
Upgrade ELM327 v1.2 (fake 1.5a) from 9600bps to 34800bps
Re: Upgrade ELM327 v1.2 (fake 1.5a) from 9600bps to 34800bps
Yes, you must have bride marked on green.EnIgMa wrote:So,
O.E.Motorsport - tuning & innovation
Hy all! I don't speak english:S
The question:
Elm 327 v 1.2 mondifyed 9600 to 34800 and working good fiat ecu scan?
My elm327 1.2a BT cabel work good if modify wires?
This is :
Please help, and paint cut and good connect!
Thanks for help
The question:
This is :
Thanks for help
I have 1.2a same llike on picture with BT my is without BT, and like on that pic pin 6 is connected to R24 but R24 is missing but there is one R under R24 do I need to remove that or what?
I have tested only connected 5V to R24 and to pin 6, now it says it is 38400bps and not working on 9600, but still I only can acces ECU engine.
1.2a all is same like 1.2 only like on this pic with BT there is place for 3 R , but one in the middle is missing.
Good evening,
That's exactly it, the metal 1.5a.
I did make this change, it actually connects 34,800.
But still no connection to the Can!
Someone he passed the CAN connection with this product?
Cordially
Cordially
