2020 ducato has no SGW?
joshh1512
Post by joshh1512 »
is anyone able to confirm if my 2020 reg plate (feb 2021 manufacture) actually has no SGW? it’s 2.3 multijet, ad blu.
i’ve stripped the dash and the glove box area has no physical module.
i’ve connected using a Vgate vlinker MC+ to multiecuscan5.3R2 direct to OBD (free version) and the scan DTC report doesn’t mention anything about SGW.
also tried alfaobd and this won’t connect to an SGW module.
does this mean my van is without?
i need to know, because i want to buy a cruise control OEM stalk second hand, but don’t want to waste money if i can’t add it via proxy alignment… and also don’t want to buy a SGW adapter if i don’t even need it!
but all the info points to me needing one…
also, is the MC+ bluetooth a suitable adapter for my needs? or should i return it and get a USB one (which brand?) as i read i shouldn’t use BT for proxy align. though this was the one which Gendan UK supply…
see photos of my two (free) scans.
thanks
Re: 2020 ducato has no SGW?
Post by s130 »
SGW
Some later models of the Ducato (and other vehicles) have the SGW integrated into the Body Computer (BCM) and there is no external module that can be bypassed.
joshh1512
Post by joshh1512 »
s130 wrote: 18 Apr 2025, 07:32 SGW
hi mate.. yes i’m aware of that, but if that was the case would the DTU scan list that it has an SGW? how would i know its built into the BCM?
shpuncik
Post by shpuncik »
you can always try by running some tests like turning on lights - if it allows to do it, then no SGW is present.
abarthmultijet
Post by abarthmultijet »
shpuncik wrote: 18 Apr 2025, 14:24 you can always try by running some tests like turning on lights - if it allows to do it, then no SGW is present.
Exactly what Shpuncik says. The 2020 manufactory date Ducato (2.3, 9hp gearbox, adblue) from our company doesn't have an SGW.
Rankman
Post by Rankman »
I have the same issue that i cannot find the SGW.
Does this mean the ducato has no SGW and I can modificatie things or does it mean it has een intergrated one that can not be bypassed and only can be programmed with a SGW license key?
Does this mean i cannot use Multiecuscan for my Ducato?
Regards,
Rankman
shpuncik
Post by shpuncik »
Rankman wrote: 28 Oct 2025, 09:09 I have the same issue that i cannot find the SGW.
Regards,
Rankman
mate, have you tried reading thread? literally couple posts above talk how to test if you have SGW or not.
Rankman
Post by Rankman »
shpuncik wrote: 29 Oct 2025, 09:58
Regards,
Rankman
j
I,ve read the Posts but with the free version I cannot test it🥲.
To buy a license and then discover that it doesn’t work is not what I prefer 😂.
Can someone explain me how I can test it to make sure it works before I buy the license?
Regards,
Rankman.
Post by s130 »
Email MES Support for advice and report back here.
Rankman
Post by Rankman »
joshh1512 wrote: 17 Apr 2025, 18:15 Hi
thanks
Did you succeed with Mes and had no SGW block 🥴?
I dis a scan and also found nothing regarding SGW.
Regards,
Rankman
