Upgrade ELM327 v1.2 (fake 1.5a) from 9600bps to 34800bps
Hello, you can made your ELM327 1.2 metal (1.5a fake clone) or plastic 1.3 from 9600bps to 34800bps. See pictures
- elm327v12a.jpg (215.75 KiB) Viewed 27868 times
- 33978446.jpg (143.79 KiB) Viewed 27866 times
O.E.Motorsport - tuning & innovation
Re: Upgrade ELM327 v1.2 (fake 1.5a) from 9600bps to 34800bps
i don't get it....
what should i do?
i probably have one like first picture...do i have to solder a cable like 3rd picture?
what should i do?
I edit the post. In first post is ELM327 1.2 (1.5 fake version). Now, here is the plastic ELM interface.
- obd2all.jpg (49.49 KiB) Viewed 27848 times
- obd2sm.jpg (80.77 KiB) Viewed 27852 times
Hello,I'm very interested in this mod. Could you give us more details? The picture doesn't show where the other side of the jumper is connected. Pin 6 of the obd plug?
No, no connect pin 6 from OBD connector. Pin 6 from Microchip to 5v. and remove/unsolder resistor R24 from sheme. Is this
When this manipulation try to connect with 34800 boud.
an for what is this mod useful? i have plastic 1.3 clone and everything works ok.
Brilliant!
I tested, it works! 38400!
Does it actually changes the speed or just fools the application?
Is it safe?
Is it safe?
There is a difference in the CAN protocol. There ECU support at higher speeds.
Should not have a damage control unit or ELM. However, do it at your own risk!
For me, this modification was necessary in consequence of the use of some other software the connection with CAN-BUS and using this ELM327.
OK. So, have you been using this and didn't have any problems?
Where did you get the idea?
I use it and no problems. I took the idea from another forum where they describe in detail the operation and say it works and no problem.
