Fiat 500 Cluster TFT - Enabling missing Features
Hello Guys, how are you??
First of all , let me introduce myself, I'm from Brazil and a owner of a 2017 Fiat 500 Pop/Cult 1.4 8v.
I'm facing a few issues since I bought a TFT Digital Cluster from Europe Part Number 07357867610 , made in Slovakia (30/06/2023) and according to the part number came from a 2023 Fiat 595 Abarth.
I'm Owner of a Fiat 500 1.4 8v 2017 made in USA.
Here is the list of the problems :
1 - Headlight leveling
2 - TPMS Light Deactivated
3 - TPMS System does not display in Cluster
The purpose of this thread is to gather all the information and help to workaround this issues and make this thread the source of the missing information such as
Custom Proxy Encoding and the meaning of each of the bytes do without breaking the car.
Does anybody knows how to add the missing features using MultiEcuScan or Alfa OBD?
The funny part is when I try to Enable the TPMS light in "MES" it gives the error : "Defect . The ECU detected that the request contains parameter(s) with value(s) outside the permitted range"
Images Below :
Previous OEM Cluster that was installed in the CAR
A) Picture of my current setup, TFT Cluster
B) Picture of Another Europe Display with the headlight leveling enabled and TPMS (Random Internet Image)
My Proxy Code
31 37 31 36 32 31 30 39 30 30 30 31 32 33 34 35 36 37 38 39 30 20 17 04 29 4F 80 00 04 11 00 00 00 09 00 00 00 11 00 00 00 01 C0 47 06 F4 00 01 70 0A 00 00 96 00 01 00 95 00 12 02 1E 01 00 70 00 00 00 00 00 00 00 00 00 45 00 00 00 00 31 06 91 01 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 00 90 18 12 00 00 86 02 00 B0 00 00 02 40 00 11 00 00 00 00 00 00 01 00 80 01
I took the opportunity to get another proxy code from a 2015 Fiat 500 Cabrio 1.4 16v MultiAir made in USA that comes with the OEM TFT Cluster and all of the missing features was there
Proxy Code from 2015 Cabrio USA
31 35 31 36 35 37 31 34 34 30 30 31 32 33 34 35 36 37 38 39 30 20 15 03 13 6F 8C 40 05 02 00 00 00 29 00 00 00 02 00 00 00 80 40 45 06 F4 20 01 75 BA 15 00 96 00 01 00 95 03 12 02 1E 01 00 10 00 00 00 00 00 00 00 00 00 45 00 00 00 00 34 06 A8 01 00 00 80
C) Picture from the Cabrio
If I workaround this issues, I`ll let you know =)
Images Below :
My Proxy Code
Re: Fiat 500 Cluster TFT - Enabling missing Features
Sorry but simple question first, did the car come originally with direct TPMS? (sensors inside the tire)
No worries! Good Question , so I really don't know where the TPMS Sensor is , i presume that is inside the tire. I've seen people talking about the "indirect TPMS" but I'll go to a Tire Shop to confirm if the sensor is inside the tire. I'll let you know.abarthmultijet wrote: ↑03 Dec 2024, 16:17 Sorry but simple question first, did the car come originally with direct TPMS? (sensors inside the tire)
With indirect TPMS you can't see the pressure of the tires on the screen. It only gives you a notification when it is noticing an change in rotation speed of the tire. Indirect TPMS works with the abs sensors.
abarthmultijet wrote: ↑04 Dec 2024, 20:02 With indirect TPMS you can't see the pressure of the tires on the screen. It only gives you a notification when it is noticing an change in rotation speed of the tire. Indirect TPMS works with the abs sensors.
i`m going to share some screens about the configuration of TPMS, The OEM behavior is tire pressure warnlng light turn on. But when I try to activate the inside the MultiEcuScan ( Dashboard --> Instrument Panel Marelli TFT) gives the "out of range error". Another problem , when I access the Dashboard config screen there is a stored error (U1700-86 - No body computer).
A) BCM Screen
B) TPMS Screen
What if you try to run proxy with both not present?
Hello!!
I did this ,but nothing happened. Both TPMS and ITPMS disabled, but the second drop down menu ( Premium, Logic 4) let me choose the "type of monitoring", I put the screen below.
I'm going to share what I did, I put the first TPMS as "PRESENT" and executed the proxy alignment. The good news , the Light of the Dashboard came up , Flashing and the center of the screen in the Cluster shows the Fiat 500 with tire , but nothing is displaying .
Images below :
1) DashBoard
2) Drop Down Menu, Types of monitoring
3) I Tried with both presents (TPMS + ITPMS) nothing changed
4) When I go in MES in System --> Other -- Tire Pressure Control (TPMS) , inside the module, When I click in the options , shows the current monitoring working, the question is , Does my car has the TPMS but I don't know which module shoud I use , in the drop down menu like :
Base , Logic 1
Base , Logic 2
Base , Logic 3
Base , Logic 4
Premium, Logic 1
Premium, Logic 2
Premium, Logic 3
Premium, Logic 4 --> Current Setup
TPMS System :
Other / TPMS (Tire Pressure Module)
ISO Code: F4 02 86 8A 5B
VIN code: 3C3AFFARXHT621090
Hardware number: 68214826AA - Ver: 05
Software number: 90551103 - Ver: 01A4
5) My current Proxy with TPMS Disabled
Well, I will try one of these options and see if it works
Base , Logic 1
Base , Logic 2
Base , Logic 3
Base , Logic 4
Premium, Logic 1
Premium, Logic 2
Premium, Logic 3
Updating the status :
I changed the TPMS to "Present"
I ran through all the options :
Base , Logic 1
Base , Logic 2
Base , Logic 3
Base , Logic 4
Premium, Logic 1
Premium, Logic 2
Premium, Logic 3
Premium, Logic 4 ---> Current Setup
Nothing Changed and the behavior still there, Tire pressure light flashing.
Fun fact , If I go to System --> DashBoard --> Instrument Panel Marellig TFT --> Actuators --> Tire pressure warning light
Now I can Disable the light or enable it in the cluster panel. When the TPMS was "Not Present" or with the ITPMS "Present" , the same option was giving "Failed to execute --> Out of range".
I begin to believe there some configuration in the cluster missing or some "bytes".
I'm still working in some solution!! =)
Base , Logic 1
Base , Logic 2
Base , Logic 3
Base , Logic 4
Premium, Logic 1
Premium, Logic 2
Premium, Logic 3
It ist possible that TFT cluster has different connection as base cluster ?
check wiring
check wiring
When I changed the Old cluster to the new cluster , the plug and wiring (18 ways) was there, maybe different pins/wiring diagram?
I begin to believe that bcm don`t talk to the cluster and the cluster don`t recognize the TPMS Module or, maybe executing custom proxy I can work around this. If I can get the proxy code from a 2023 Fiat 595 Abarth , maybe I can translate to my car
See, I have this stored faults when scanning DTC`s
Body Computer Delphi (312) MY12
ISO Code: 40 83 EC 8A 0E
Hardware number: P500L2EU304 - Ver: 03
Software number: 28486828 - Ver: 0702
Errors found:
U1703-86 - Instrument Panel node - Signal/message invalid
B10AA-4A - PROXI configuration control - Incorrect component installed
Dashboard / IPC (Instrument Panel Cluster)
ISO Code: 00 03 40 25 14
Hardware number: 50019650001 - Ver: 00
Software number: 04005440562 - Ver: 0432
Errors found:
U1700-86 - No Body Computer - Signal/message invalid
U1706-86 - NFR Node absent - Signal/message invalid
and now My Odometer is Flashing =( , MeS is telling the proxy is correct and don`t need to be aligned
My current Proxy
CAN CONFIGURATION DATA:
4F 80 00 04 01 00 00 00 4F 80 00 04 11 00 00 00 09 00 00 00 10 00 00 00 09 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
4F 80 00 04 01 00 00 00 09 00 00 00 01 00 00 00 4F 80 00 04 11 00 00 00 09 00 00 00 11 00 00 00 09 00 00 00 11 00 00 00
31 37 31 36 32 31 30 39 30 30 30 31 32 33 34 35 36 37 38 39 30 20 17 04 29 4F 80 00 04 11 00 00 00 09 00 00 00 11 00 00 00 01 C0 47 06 F4 00 01 70 0A 00 00 96 00 01 00 95 00 12 02 1E 01 00 70 00 00 00 00 00 00 00 00 00 45 00 00 00 00 31 06 91 01 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 00 90 18 12 00 00 86 02 00 30 00 00 02 44 00 D1 00 0F 00 00 00 80 01 00 E0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Side Acceleration / Yaw Node (NYL)
Airbag Node (NAB/ORC)
Tire Pressure Node (TPMS)
(Multiecuscan 5.3R1)
22/12/2024 12:14:06
Fiat 500 1.2 8V
Side Acceleration / Yaw Node (NYL): Ok
Airbag Node (NAB/ORC): Ok
Tire Pressure Node (TPMS): EOL Ok
Entertainment Telematic Node (ETM): EOL Ok
