Salut et merci pour ton tuto Gogogadget
pour moi Stelvio quadrifoglio 2019 avec stage 1
j'ai suivi le tuto et hop hop parfait, donc la voiture fait un bip aprés une seconde elle rebip une fois et aprés deux seconde elle démarre
les modifications comme ceinture desactivé, module star stop désactiver instalé , ou bien frein électrique désactivé cela ne change rien le démarage a distence fonctionne voiture dans le garage sa fontionne aussi, essence 50% sa fonctionne aussi
pour savoir ou ce trouve les onclets il suffit de cliquer sur les chiffre et en bas a gauche les onclets son déffinis
Hi and thank you for your tutorial. Gogogadget for me Stelvio quadrifoglio 2019 with stage 1, I followed the perfect tuto and hop hop, so the car makes a beep after one second, it beeps once again and after two seconds it starts:) Changes as belt disabled, module star stop disabled installed, or electric brake deactivated, it does not change anything, the remote start works:) car in the garage, its also works, gasoline 50%, its also works:) To know where are the onclets, Just click on the numbers and in the bottom left, the onclets are defined.
merci.
Alfa Romeo Giulia enable remote start engine
Re: Alfa Romeo Giulia enable remote start engine
Hi all,chrener wrote: ↑29 Oct 2021, 19:25 Hi!
I have done fobik programming with remotestart and panic enabled and keyfob buttons type 5 buttons also...
So have one problem...
Panic works well, but remote start dont operate... After twice press of button it just once flash with once horn ... Thats all...
Where could be a problem?
THX a lot!
same Problem here, new Chinese Fob works as it should be. I have changed Byte 108 from 06 to 07 but my car (Stelvio 2019 280 HP) only reacts with one blink - one honk. That´s all.
Is there any method that tells me what prevents the car from starting the engine? The car has full tank, all doors closed and stood still all night.
Here are my Proxy Bytes
30 34 36 33 30 30 34 34 32 35 39 4F 55 54 50 55 54 2D 53 49 54 20 19 05 15 4F 0C 40 65 10 40 19 22 2A 08 00 00 80 40 00 00 4B 0C 00 65 10 40 19 22 0A 00 00 00 80 40 00 00 43 5D 27 01 A9 8B 08 D4 54 37 A8 07 40 20 10 0A AF 1E 04 72 00 35 73 14 01 4F 03 34 1D 8B D4 48 2C 43 05 00 80 00 0E 92 00 00 19 04 00 09 00 5E FA 81 07 E5 01 31 20 01 76 15 00 81 10 01 00 DB 00 B7 10 12 00 3D 49 03 03 12 F9 57 20 00 00 01 00 00 80 20 08 18 89 0A 00 00 00 00 00 0E 56 00 00 00 40 B1 00 00 00 03 00 02 01 00 10 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Thanks in advance
Hood switch is enabled?
