Alfa Romeo Giulia enable remote start engine
mandax
Post by mandax »
Do you know how can enable remote start engine from heyfob? I have a special keyfob with start but i don't find the codding for this function
Re: Alfa Romeo Giulia enable remote start engine
in byte 108 set bit 0 to "1"
mandax
Post by mandax »
I will try now,thank's man !
mandax
Post by mandax »
from 06 to 01 ?
30 34 36 32 30 30 35 37 31 33 34 4F 55 54 50 55 54 2D 53 49 54 20 16 11 14 4F 0C 40 65 10 40 19 02 0A 00 00 00 80 00 00 00 4B 0C 00 65 10 40 19 02 0A 00 00 00 80 00 00 00 43 5F 6F 02 A9 83 07 F3 34 2B A1 07 40 10 10 0A A3 28 04 F2 00 35 73 14 01 4F 03 34 1D 83 AC 48 06 43 05 00 A1 00 0A 3C 00 00 19 04 00 01 02 5B 9D A1 06 ED 05 31 20 09 72 14 3D 89 10 01 00 EE 00 F7 10 10 00 3D 49 03 03 12 F9 57 80 00 01 01 00 00 F0 20 08 18 81 0A 00 00 00 00 00 0A 14 00 00 00 00 00
mandax
Post by mandax »
Not work with 01 and 07
this should work:
30 34 36 32 30 30 35 37 31 33 34 4F 55 54 50 55 54 2D 53 49 54 20 16 11 14 4F 0C 40 65 10 40 19 02 0A 00 00 00 80 00 00 00 4B 0C 00 65 10 40 19 02 0A 00 00 00 80 00 00 00 43 5F 6F 02 A9 83 07 F3 34 2B A1 07 40 10 10 0A A3 28 04 F2 00 35 73 14 01 4F 03 34 1D 83 AC 48 06 43 05 00 A1 00 0A 3C 00 00 19 04 00 01 02 5B 9D A1 07 ED 05 31 20 09 72 14 3D 89 10 01 00 EE 00 F7 10 10 00 3D 49 03 03 12 F9 57 80 00 01 01 00 00 F0 20 08 18 81 0A 00 00 00 00 00 0A 14 00 00 00 00 00
also why do you have byte #59 set to "5F"? it should be set to "5D" on EU cars or try to set it to "5E" when using US key fob.
mandax
Post by mandax »
Ok,I can try this after 5 pm today. Thank's again!
mandax
Post by mandax »
Modify 59 in 5E 108 in 07 .Just blink once the signal and nothing else.I think is not compatible my car with this settings.
mandax wrote: 19 Jul 2021, 15:37 Modify 59 in 5E 108 in 07 .Just blink once the signal and nothing else.I think is not compatible my car with this settings.
never tried to activate it on diesel engine. when you try to remote-start and it fails, scan whole car for DTCs. maybe there is some error which prevents it to work.
usually you need have enough fuel so remote-start could work.
mandax
Post by mandax »
All requested conditions is available.Full tank,full battery,no errors on all modules.Diesel is a little demon now !
