Hello Yani
I've downloaded the 2.3v and I found in adjustametements a new parameter for my Croma 1.9 Mtj 16v: particle filter
So now there are: "particle filter regeneration" but also the old one "particulate filter regeneration".
There are both of them...
But aren't them the same thing? Which are the differences?
Thank you!
Particulate and Particle filter regeneration
Re: Particulate and Particle filter regeneration
Please read carefully. These are two different procedures:
1. Particulate Filter Replacement (only for version with DPF)
2. Particle Filter Regeneration (only for version with DPF)
The "replacement" procedure will also clear some counters (number of regenerations, number of incomplete regenerations, etc.) related to your DPF.
right thanks
But which of them is a new function?
I remember that in v2.2 there was only one of them...
but are them the same thing? I mean, is the difference between them that "particulate replacment" only clears some parameters? Or not?
