i dont think i can help you much more, as i am going on that you have a uconnect 5 not your car.
there is a guy on this site goes by the name ABARTH he is surpose to be good with codes.
sorry i cant help any more..........
Uconnect 5 Poxy alignment issue
Re: Uconnect 5 Poxy alignment issue
Cheers for trying .The radio is a uconnect 5 but it doesn't have dab if. I disconnect the radio, it aligns ok no milage flashing. Till I reconnect the set, then off it goes flashing again. I will reach out to ABARTH and see if he can help .
the only thing can think of and its worth a try is, on the bite 123 change it to 00 as your one says 01
hiya changed 123 from 01 to 00 but still comes up with an error/ Entertainment Telematic node (ETM) Failed! - Request out of range error
!!!!FIXED!!!! changed byte 121 from 40 to 44 did a proxy alignment all coding succeeded. Thanks Shelby1 for your help
well done you, have a pat on the back.
hope to speak again soon............
Deffo take care
