Uconnect 5 Poxy alignment issue
Cyanigosa
Post by Cyanigosa »
Hay all, I've just joined this merry site due to me having an issue with Poxy Alignment. I have a 2014 Swift Ducato 250, which seems to have a replacement / upgraded radio in it. From what I can gather it used to be a VP1, but now has the VP2 with navigation. The problem I have is the dreaded milage flashing, which after 5 hours driving makes my eye twitch :D . So I purchased this kit to carry out an alignment, but it keeps failing the error I get is Entertainment Added/EOL failed. Is there any way I can leave this set in but stop the milage flashing.
Cyanigosa
Re: Uconnect 5 Poxy alignment issue
Post by Cyanigosa »
Hay all just been through the other posts and was unsure what information you guys my need so here goes (if it helps) . Fiat Ducato 250 multijet 2014.
I think the old radio was a uconnect 3 but I'm not sure, as the van is a motorhome they replaced the radio with a vp2 set with Nav but no DAB the radio works perfectly but i have the flashing Mileage as normal the proxy does not work comes up with added / error so the mileage still flashes. As other posts here is my config
30 38 32 35 30 32 30 36 33 34 32 4F 55 54 50 55 54 44 4A 49 54 20 14 06 09 4B 00 00 04 10 00 00 00 09 00 00 04 10 00 00 00 11 40 53 08 B1 00 7C 00 00 00 00 26 00 00 00 8C 06 0B 02 60 C0 12 50 00 05 00 05 04 00 00 00 00 56 00 00 00 00 12 10 42 03 11 24 00 FF 00 05 00 80 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 01 00 00 85 12 00 04 00 00 00 40 00 01 00 00 00 00 00 00 01 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 1F 00 00 20 00 00 02 FF
Thanks again Cyanigosa :D
Cyanigosa
Post by Cyanigosa »
Hay all does anyone know if this could be done ? or could someone point me to the meaning of the code if possible as i would really like to stop this milage flashing
shelby1
Post by shelby1 »
hi, have you tried changing byte 121 from 40 to 44
Cyanigosa
Post by Cyanigosa »
Hay Shelby1, thanks for the reply. No I haven't tried anything at the moment. Silly question I have a registered copy of multiecuscan, I know now how to retrieve the poxy code, how would you change it ? . Was a master tech for 35 years but never delved into this side of it :-)
shelby1
Post by shelby1 »
hi, i am very new at this as well,
ok using proxy do a read from you car then press the adjustments at the top left of your screen then press ctrl and alt c together, you will then get box come up, copy and paste those numbers to note pad and save (this will be your back up should you need it) then count each pair of numbers starting from top left going right and same on the next line down.
each pair of numbers or letters are one byte, then find the byte you need and change to what you need to change it to then press execute (bottom right of your screen)
hope this helps.........
IF ANY ONE THINKS I HAVE GIVEN WRONG INFO PLEASE JUMP IN.............
Cyanigosa
Post by Cyanigosa »
Hi we managed to change byte 121 from 40 to 44. It changed the proxy from added to just EOL Failed but the milage is still flashing.
Cyanigosa
Post by Cyanigosa »
AArrr thought i had it then. Did a alignment without the radio attached then switched off ign left it off for about 2 mins turned it back on no flashing reconnected the radio all ok no flashing. great so i though i would just change back some settings I had changed did the same disconnected the radio, reset the changes i made now the milage flashes when i re connect the radio.
shelby1
Post by shelby1 »
does the radio have dab ?
Cyanigosa
Post by Cyanigosa »
Hay, nope just tomtom nav and the normal bluetooth and phone all built in.
