Shhhh!!! He works for Bosch!Jerry 159 wrote:Did you try it yourself with ELM327 interface?
NO you did`t !!! because it works!
DPF regeneration failed
Re: DPF regeneration failed
'03 Fiat Stilo MultiWagon 1.9 JTD Dynamic
DPF regeneration errore sconosciuto ma ok
a metà della rigenerazione dopo il fumo allo scarico il programma mi da errore sconosciuto e mi chiede di premere il tasto Y
ovviamente clicco il tasto Y ed il programma torna alla schermata parametri, poi se schiaccio il freno il motore torna al minimo e la rigenerazione e completata, ma credo che l'errore sconosciuto sia un problema del programma, me l'ha fatto su due alfa 159 1.9 150cv ovviamente questa prova e stata fatta con cavo elm.
si puo risolvere questo problema?
ciao.
ciao.
no at all. lol but for diag i use kts. yes work the latest 2.0 and 2.1 with can elm because prevouse version is impossible with k_lines and old 1.6.topogatto wrote:Shhhh!!! He works for Bosch!Jerry 159 wrote:Did you try it yourself with ELM327 interface?
this software is only readers value with very bad values and can't diag your engines. but good job for low cost device.
don't wotk fine for me dpf obsturation stay a the % after regeneration.
Hello yani. multiecuscan work perfectly on my 159 with elm 327 1.3a and when i make DPF regeneration he work ,start at 3000rpm for +-5min and finish ok.
odometre at last regeneration is ok 0km but obsturation is stay a 70% the same at the begining and continu give up and no reset to 0% or 10% like ecu regeneration .
How long does it take to regenerate the DPF?
Because I've set a timeout of ~3 minutes... and if the procedure does not finish for that time the program shows error.
yes after 3 min regen finish and no error appear with "odometre at last regeneration is set to 0km ok but % of obturation is at the same value.
Ok, I see. I will increase the timeout to 10 minutes in next release.
I think, however, that if you are patient and don't stop your engine after those 3 minutes, you can successfully finish the regeneration process (even though Multiecuscan has stopped and reported an error).
yes i don't touch the car in regen i wait the car finish.
with automatique regen from ecu, regen run for 8 at 12 min for me.
DPF Regeneration for 159 2.4mjet
This is an interresting discussion regarding regneration on a 159 - 1.9. I have just had my EGR changed as the car basically shut down on my. My travel is short city runs. I presume is teh main cause of my engine woes. Choice is sell or do more maintenace. So teh question is, can I do a forced regen on my 2.4l 159, how often and what is the impact on engine for doing this?
