Uconnect 7" fiat tipo enable DAB
Re: Uconnect 7" fiat tipo enable DAB
Ricevo un errore anche con proxi di fabbrica (backup). Com'è possibile?
Ma spiega che hai fatto alla vettura...perché non vedo il motivo di fare un allineamento proxy se non hai cambiato centraline...
ciao a tutti ..qualcuno s a come abilitare la porta AUX ?? provato con MES e ALFAOBD ma non si abilita..con le varie configurazioni veicolo combinazioni AUX , AUX USB, AUX USB SD, AUX USB1SD USB2 m anon cambia nulla .
ho sostituito il pannellino solo USB con un altro AUX USB il cablaggio è lo stesso e i fili sono tutti collegati alla radio..
Hello everyone,
I have read all the comments here,
here I am busy on a late 2018 abarth, which 7inch screen has DAB, carplay/AA and Beats
I am trying to change the coding to enable navigation,
I have the Byte 121: 70, I modified it to 40 and 44 but no change, (the abarth has the Beats option, so for me it would be 44)
I do not understand why it does not work, when I have already changed, on another abarth, the car radio 5inch -> 7inch, I was able to activate the NAV and DAB without problem.
Of course, I have the receiver box for the NAV.
if you have any idea how to make NAV work and activate it, I will be grateful !!
This my dump :
33 32 31 35 30 30 34 39 33 35 33 4F 55 54 50 55 54 44 4A 49 54 20 19 03 14 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 C7 75 06 FE 00 1C C0 00 00 00 16 00 01 00 94 06 01 01 00 40 00 02 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 15 00 94 08 52 30 04 95 00 00 20 80 00 00 70 00 95 00 0F 00 00 00 80 05 00 C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
This my dump :
