Anonymous375298
Post by Anonymous375298 »
peppect84 wrote: 28 Oct 2019, 23:53 I tested the resistances one by one, none is 100ohm...
According to the original post of this thread the resistance that you have to change is 120 Ohm, not 100 Ohm. You have to change the 120 Ohm resistor for a 100 Ohm one. And you have also to change some capacitors but I don't understand how that part works.
Here you have the quote:
yani wrote: 12 Sep 2010, 20:50 The problem is actually in the CAN termination method used in these interfaces - they use one 120 Ohm resistor connected between CAN-L and CAN-H.
According to the ELM327 datasheet the proper termination is to use 100 Ohm resistor on each of the 2 lines connected to ground through a 560 pF capacitor (see the picture below).
So i just got two 100 Ohm resistors and two capacitors of 560 pF and fixed my interface as shows below. And it WORKS flawlessly now.
Trannguyenpc
Post by Trannguyenpc »
Tôi đã mua 1 đây vagkkl+Fiatecuscan từ Trung Quốc để kết nối ecu của tôi, nhưng hoàn toàn thất bại, mong sự giúp đỡ mọi người
I bought 1 vagkkl + Fiatecuscan from China to connect my ecu, but it all failed, I hope to help everyone.
Alfred Romero
Post by Alfred Romero »
Hello. I have Viecar bluetooth 4.0 OBD2 scanner and can connect to the engine module only. All other modules dont connect. I am using AlfaOBD paid version on my Android phone. Can someone help me to detect which resistor should be removed if possible?
Photos here:
https://ibb.co/KLR9PLr
https://ibb.co/ZJkXTc4
Trannguyenpc
I finally connected successfully to my ecu. I bought an obd2 cable for 124,000 vnd (Việt Nam) , from https://s.lazada.vn/s.90Q9.
I connected and checked the error on the my car Fiat siena 1.6 (error code P0351 Ignition Coil 2) with the mutiecuscan 4.5 software and the Fiatecuscan software 3.6.2.
Thank you and everyone for your help !!!
gsm
Post by gsm »
For all, I bought the Stardiag interface and can connect to almost everything so my problem is solved so far
AlanHoffmann
Post by AlanHoffmann »
Please, someone for Help me? Not connect
ale123
Post by ale123 »
Hello guys,
I bought this obd scan Vgate for my alfa 147 1.9jtdm but I can't connect with MES. :( Can you tell me wich resistor should I remove? I was reading others post, but I didnt find model like my. I am sorry if i didnt see it. Thank you very much for help
https://postimg.cc/4mXXDKqf
https://postimg.cc/N5bQBsv1
https://postimg.cc/ZWR4qGJX
scarface53
Post by scarface53 »
hello,I bought vgate icar 2 wifi version
the board is that,but I can't connect to multiecuscan body,proxyaligment etc,only engine, I can't find 121 resistor,can you help me? thank you
https://i.postimg.cc/bNjDkV0n/IMG-20191228-020357.jpg
https://i.postimg.cc/MTCcsdhh/IMG-20191228-020402.jpg
handynoturno
Post by handynoturno »
Guys, first make sure that the interface used is actually implemented with the 121ohms resistor
check below:
https://www.youtube.com/watch?v=emzyE-zkGmw
resistor that must be removed:
https://ibb.co/tczXLW2
After checking that between pins 6 and 14
is showing 120 ohms on the multimeter, look for it on the board and remove it
Sorry my bad english.
Mark1
Post by Mark1 »
Hello everyone!
I have read and experimented a lot with the best value for money tool.
So far I have come to this tool: https://www.aliexpress.com/item/32862479065.html?spm=a2g0s.9042311.0.0.5d824c4dJTLVmL
I've tested many of the same looks, both old and new, and foror at similar prices , ONLY this device seems to be good.
(So far I've only tested it with key programming radio and immo)
I hope I help with it, so I wrote this so that everyone doesn't buy as much cheap equipment as I do.
BR.
