I don't understand. So you can turn off the light but what you want is change the number of KMs until the next oil change?
I want to switch off the service interval light and that must be done under Service and I can not connect to the service so I can not do service interval reset
Hello Guys, i have read alsmost half them with faulty ELM 327 and conection, but stil can't find an answer.
I have the next ELM 327 1.5a, MultiEcuScan 4.4 (free) and Windows 10 64 bit pro
The car of my wife is Mito 1.4T 155hp.
Have a one problem during cold start in the morning in the last some months, and i want to check some sensors.
So that's the ELM module which i bought:
https://ibb.co/wQNC0vt
I have removed the resistor "121" R2 - i think is correct
https://ibb.co/Wc60BM2
https://ibb.co/mGSQRZG
But still not working properly
https://ibb.co/T2NWWzF
When push Scan button to check for inteface and ELM, every moduls say OK, the bottom report lane looks like " This interface is compatible with ELM327 version... and will connect to any CAN module. But the result is on the last picture. I have no idea where is the problem. If someone can help me will be highly appreciated, In my country no one can't.
Thanks in advance!
Regards
Thanks in advance!
Regards
Blizzard wrote: ↑17 Oct 2019, 14:06 So that's the ELM module which i bought:
I am not familiair with that kind of interface so I can not help you with that one
If I look on page one there they talk about R14 which should be on the backside
Did you choose the right module ? If not then you get the same message
gsm wrote: ↑17 Oct 2019, 17:55Blizzard wrote: ↑17 Oct 2019, 14:06 So that's the ELM module which i bought:
If I look on page one there they talk about R14 which should be on the backsideBut still not working properlyon the backside doesn't have resistors or capacitors is flat plate
Yes ofc there is easy![]()
I'll check again with some other drivers, also i have changed the Latency into the registry so we'll see. If have any updates I'll let you know
You could ask via email to the distributor of your country about what cable do you need.Blizzard wrote: ↑17 Oct 2019, 14:06 Hello Guys, i have read alsmost half them with faulty ELM 327 and conection, but stil can't find an answer.
Thanks in advance!
Regards
Here you have a list of distributors: http://www.multiecuscan.net/Distributors.aspx
Look here, all interfaces are tested with MES and should work fineAnonymous375298 wrote: ↑19 Oct 2019, 01:58 You could ask via email to the distributor of your country about what cable do you need.
https://www.multiecuscan.net/HowToUse.aspx
I bought the Stardiag and I receive it yesterday but I have no time to test it in my Ducato X250 from 2011
And reed https://www.multiecuscan.net/SupportedVehiclesList.aspx
Look at your car model and type and read what you need
Hello Guys, thank you for your support but the problem doesn't have touchable points with vehicles list or any other because just i need to connect with the engine, so for there no need any special color cables.gsm wrote: ↑19 Oct 2019, 08:05Look here, all interfaces are tested with MES and should work fineAnonymous375298 wrote: ↑19 Oct 2019, 01:58 You could ask via email to the distributor of your country about what cable do you need.
I did another think, have download version 2.1.2 Alfa OBD (it's a one old version of Multiecuscan) but now can connect with the engine, can read data and faults. So i think the issue isn't the ELM module.
Of course i didn't give up to connect with multiecuscan 4.4 and still trying to find where is the problem. If you have any ideas i'm open for them
Regards!
what resistance should I remove from here? I can't understand it
I tested the resistances one by one, none is 100ohm...
