caiobaio
Post by caiobaio »
I apologize my English
I elm 1.4 + just bought sftdi chips installed driver with multiecuscan works but if I use yellow cable no (bought later) I think I have rebuilt the pins odb wrong can someone confirm the sequence I enclose photos of the card to know model maybe problem resistance by line can? maybe welding on pic connects 2 pins? thank you for help
[imghttps://imageshack.com/a/img924/1202/ciSTrO.jpg][/img]
[imghttps://imageshack.com/a/img921/6665/LPfiB6.jpg][/img]
caiobaio
Post by caiobaio »
csorry my english i bought elm 327 version 1.4 + multiecuscan works in the normal way if I use yellow a3 cable does not go pin 1-6 9-14 before the yellow cable unassembled pin cone now I think maybe soldered again but wrong or maybe problem issue allego photo desperate thanks
caiobaio
Post by caiobaio »
misurato con tester pin 6 e 14 risulta 160 ohm poi scende a 0 riposto imagini forse riesco a postarle questa volta scuso di nuovo mio inglese
brulkjaer
Post by brulkjaer »
This is my interface.
Witch resistor must be removed?
pedro1988
Post by pedro1988 »
xusete wrote: 28 Nov 2017, 16:20 Hola!
I am trying to access to body in a alfa 147 1.6 twinspark 2004. I have an Elm327 wifi interface and can't find the famous 121ohms resistor I am supposed to remove.
Resistance between pins 6 and 14 is 50kohms (according to my multimeter).
Board is so so tiny! :?
Hello, I have the same PCB, have you got to know what is the resistance that needs to be removed?
kokkolin
trying to modify an elm327 Forscan
Post by kokkolin »
hello, I received an elm327 but it's been modified for Ford and Mazda, could I change something to make it work for Fiat and alfa Romeo? I've managed to connect it to the Fiat but only on the engine module, can something be done to access other modules?
JTDperf
Post by JTDperf »
https://imgur.com/a/2N0zuzE
Removed r14 but this stil not work.
Says interface not suitable
Car is alfa 159 1.9 jtdm
Leonardo87
Post by Leonardo87 »
Hi guys! Greetins from Brazil!
Here I purchased one interface with "PIC" chip. Can somebody help me, about wich resistor can I remove from my board? (I need to read the CAN, align PROXI and I cant!) Pics below... My car is one Fiat Stilo Abarth 2.4 20V 170cv. Thanks in Advance!!!
There is! Any help will be much appreciated! Mine board got the "PIC" chip.
Thank you guys!! :) :)
Leonardo87
cxem wrote: 07 Aug 2018, 06:18 Your ELM327 works only with OBD-2 protocol
You need to buy ELM327 on a PIC chip
https://www.youtube.com/watch?v=TeeUCoppzJc
Despite the color, mine board got the PIC chipset and a lot of resistors... Only the number 1 removed. Dont read my Fiat Stilo CAN system...
Any help will be very very appreciated. Thanks!
Jordandc
Post by Jordandc »
Problem with connect to grande punto Can
Its elm 327 wifi
