DRL settings for freemont failure on 3.6
Jumped from 3.4 to 3.6 and DRL settings for fremont are not working anymore.
Reverting back to 3.4 and all works OK.
Still did not test 3.5
Thank you for fixing
Re: DRL settings for freemont failure on 3.6
I'm new to MES, but today, using version 3.6, I have sucessfully set up DRLs (high beam / Canada) on my Freemont.
The point is that actual DRLs activation command (Not Present -> Present) seems to work correctly.
The problem is that when you open the setting again (after turning it ON) it still displays "Not Present" (although DRLs are actually activated).
So looks like the issue is not about inability to turn DRLs ON or OFF but rather in wrong displaying of DRLs status.
Hope this helps.
Anyway, it would be great if this is fixed as it's really misleading.
Hope this helps.
Thnk you keebo,
I saw this but it is not the only problem; whatever command I try to give, I get an error ("Error during execution" or similar popup, I can't remember) and the parameters are not changed.
It is not only visual in my case.
Thank you.
Thank you.
I will do it on saturday i hope to get it done... i have a freemont.. what you guys suggest, high or low beams ?
That totally depends on your personal preference and, probably, legislation in your country.
I'm doing high beams so far
thanks keebo im from Brazil.. maybe no legislation lol.. but should be low beans i will do it with 8v..
Nope. Already asked in another thread but the developer is silent...haffonso wrote:anyone knows the difference between drl canada and Europe?
I activated the DRL on my FOG lights.haffonso wrote:I will do it on saturday i hope to get it done... i have a freemont.. what you guys suggest, high or low beams ?
I changed the FOG lamps with a couple of brigth white LED lamps, excellent result for my taste.
Hello! Just enabled my DRL in low beams with 6.6V . Everything was ok and its running fine..
I'm still trying to identify Europe 1/2 and 3..
