albert
Post by albert »
OK.
Theese are the screenshots of my test with EasyOBD, ScanMaster and MES !
badcat
Post by badcat »
I have this interface elm327 wifi:
https://drive.google.com/open?id=0B7_IY ... DJDN3lLcXM
I do not understand what resistance I have to remove. :(
badcat wrote:Hello,
hi badcat
Wiso you choose a resistor on the board?
Without a description what problem you have can help you hardly anyone here
- Vehicle?
- Model?
- Bj.?
- Control?
- Is the ELM compatible with MES?
emekilker wrote:hi friends,
my car 2008 Grande Punto 1.3 MultiJet. i want cruise control enabled.
my elm 327 this:
i did this modification:
i use this drivers:
but i can't connect to body. i can't enabled to cruise control
How i can this?
As you already write in your post you need a CAN bus switchover
So you can 1 + 9 Around the CAN bus, the pins
A direct connection I would not be prepared.
luka78
Post by luka78 »
Hi, i bought ELM327 and it works with almost all phone/tablet diagnostic software.
But when I try to connect it to multiecuscan, it said this (Fiat Bravo 1.9 16V):
Please connect the interface to a car!
Scanning ...
ELM 327 v1.3+ (Bluetooth) interface found at port COM5, speed 115200bps
And it can't, I try everything. In attach there is photo of ELM (i had some problem with picture upload so I'm sendig it like this, maybe forum moderator can help me):
http://s33.postimg.org/4vgw585jz/ELM327.jpg
Is your ELM 327 Bluetooth Interface?
and MES, the free version?
And further :
If the result is displayed in the interface test of MES.
Can the interface does not work with MES and is not compatible
Then it is useful not to remove the bridge resistor also
luka78
Post by luka78 »
Alfaeddy wrote:Hello
And further :
Thank you for your answer
1. Yes it is bluetooth version and MES is free version
2. Yes, this warning is displayed in MES test interface. When I press test in MES settings, I get this note.
So, what should I do?
Greetings
p.s.
Can forum administrator help me with picture upload from link that i put in previous post?
I have heard of another user that the free version of MES no Bluetooth connection can be established.
This is only possible with the registered version?!?!
But if your interface does not pass the test
it does not work with MES
and you have to buy another interface.
Also I can here not set more pictures !!
And also get no info why ??
luka78
Post by luka78 »
Uh. Ok thank you. I will try with registered version somehow.
I don't understand you for the picture upload, I couldn't upload it so i put link.
inotalas
Post by inotalas »
Hi all, first of all congratulations to this community, there's a lot of very useful information.
I'm writing here because I bought an ELM 327 adaptor and I can't connect to a Fiat Marea JTD 105 '01 ECU. The test on MES are correct and the interface returns every command with OK but it can't connect to ECU.
Looking the first post I see that my interface have another PCB design and I don't know where to start to solve the problem. If someone can help me, see pictures attached below.
Thanks in advance.
