Connection problems with ELM327
Jan_156
Post by Jan_156 »
Hi @ all!
First, thx to Yani for the great Ecuscan software! I´ve got two interfaces, KKL and Elmcan II with ELM 327. I bought the ELM in 11/2008, the reseller said it has the chipset version 1.3a (can I prove this?). I´ve got a Stilo and tried to connect with the Elmcan, but the connection always times out, message says I have to check cable and connection settings. Cable is ok, new FTDI drivers and actual .net Framework is installed. I can connect with Scanmaster software to the ECU, but not with Multiecuscan. Do I have to change some settings in the Windows Device Manager like the KKL interface?
Greetz, Jan
Crombel
Re: Connection problems with ELM327
Post by Crombel »
I had the same problem.
I got the advice from hanzs to change the baud rate in the settings of Multiecuscan to 38400 and the problem was solved.
Jan_156
Post by Jan_156 »
Wow, that was simple. Thanks for your (and Hanzs) advice, now ELM works fine!
BR-Scan
Post by BR-Scan »
Can you connect to the ABS and airbag ECUs with the ELM interface? Does it need to bridge the pins 1-3-7?
topogatto
Post by topogatto »
BR-Scan wrote:Can you connect to the ABS and airbag ECUs with the ELM interface? Does it need to bridge the pins 1-3-7?
viewtopic.php?p=1616#p1616
Bye
Diego
'03 Fiat Stilo MultiWagon 1.9 JTD Dynamic
luks
Post by luks »
can`t connect with ELM. VAG works fine, but ELM not.
i try like you suggest but nothing with this.
any conception ?
ionio-zante
Post by ionio-zante »
luks wrote:can`t connect with ELM. VAG works fine, but ELM not.
any conception ?
I've had the same problem... Despite the changes i have done to USB serial port in the Device Manager the program still gave me errors about "Connections times out"
So i have made that trick... In the USB serial port in the Device Manager i put "Bits per Second" at 38400 and the "latancy time 1". But in the Multiecuscan program at settings button i put speed 9600 bits. And with this trick it works perfect.
luks
Post by luks »
my ELM is on real COM - RS232, there is no settings like latency time.
whatever, i will try Your trick with different values of "bits per second"
CBRider
Post by CBRider »
I have problems with the installation oft the drivers on windows 7, 64 bit. If i use the ELM on windows XP the drivers instals correctly, but on windows 7 i have the problem that under system the fault code 31 pop up. Can somebody help me ?
mican
Post by mican »
hi i have elm327 end i have problem don't connect on abs airbage dashboard but on engine works can you help my thaks
