Hello Pumpingiron91
The bridge resistance I have highlighted in red frame
Who is responsible for problems with the CAN bus protocol
But even for CAN bus problems for other read error, this is not the problem
Hi Luca Rossi
Here also again, your board has no bridge resistor
I would ask at your first post already are
Which vehicle you would like to read?
Year of construction?
Control?
Your interface has no errors I can see
Control?
pumpingiron91
Oohh, and what's my job with this? Change it or only remove? If i remove than connect the 2 sides of each other? Last question, when i use the MES i can do everything only in the ECU, in other modules all time writes for me: elm connection failed.... if its important its a 2003 Stilo 1.2.
Mfg
Roland Cseke
Mfg
Roland Cseke
lucarossi.1963
car fiat punto 1.3mjt 2009Alfaeddy wrote:Hi Luca Rossi
Control?
diagnosis engine
resistance bridge I had already removed the R27 facceva bridge between 6-14 plug eobd
the problem is that I can not connect to the interface multiecuscan and if I select the com port (assigned to the interface in computer resources) when I run the test me error:
RESPONSE: ATZ
ELM327 v2.1
ELM327 v2.1
RESPONSE: ?
RESPONSE: ?
RESPONSE: ?
Hi Luca Rossi
A ELM327 v2.1 does not work with Multiecuscan
since there is no possibility
So I asked if there is a v1.5 or v2.1 a
You need to other ELM Interface
Hi eddy this is azeem , I have the same problem as lucarossi with my elm327 v2.1 Bluetooth with multiscan and even all android obd apps it says unable to connect to ecu .
My car is fiat palio stile (facelifted) 1.6 16 v (Indian version) with 3 pin to obd converter ..
Any help ? What obd device I need and any chance getting elm327 Bluetooth to work on this car ?
Cheers
Cheers
I believe that this vehicle use VAG/KKL. I also could not connect the MES with a Palio 1.5 1996azzu wrote:Hi eddy this is azeem , I have the same problem as lucarossi with my elm327 v2.1 Bluetooth with multiscan and even all android obd apps it says unable to connect to ecu .
Cheers
lucarossi.1963
Hello everyone, I wanted to change the chip MCP2515 with a version V1.4 type the PIC18F2580, but this chip is not found in 18 feet to be welded, so I ask you, there is a chip in 18-pin compatible with version V1.4
Maybe not so simple just change the chipset, which can use a different circuit. Why do not you just buy a version 1.5 ???lucarossi.1963 wrote:Hello everyone, I wanted to change the chip MCP2515 with a version V1.4 type the PIC18F2580, but this chip is not found in 18 feet to be welded, so I ask you, there is a chip in 18-pin compatible with version V1.4
Hello!Alfaeddy wrote:Hello Tasmo
Remove the Resistor in the red Frame
and you can read the CAN Bus Protokoll
of your Car
I have a ELM327 USB with PCB like in photo.
It connect only to engine ECU, not to other ECU.
I see my interface is similiar to Tasmo's one (viewtopic.php?f=5&t=1493&start=1680),
but it has more component on the right (in my photo) that weren't on Tasmo's PCB.
How I can solve?
Thanks.
- pcb_02.jpg (471.25 KiB) Viewed 12211 times
- pcb_01.jpg (554.31 KiB) Viewed 12211 times
