FES won't connect with Adapter Cable 3
Re: FES won't connect with Adapter Cable 3
Waltomatic wrote:
Alfaeddy wrote:hello
In this ELM all possible circuits are housed in 2 switch positions, there is no need for adapters.
viewtopic.php?f=5&t=4297&p=15111#p15111
Exactly, but it's not a "dip switch", it's a "change-over switch", as I said...
But this switch replaces all adapters (A1, A3, A4 purple)
This is a multi-switch
not as the simple CAN bus switching
Racing Man
Post by Racing Man »
So when activated, connect together pin 7 and pin 12 (making a bridge)? I need just to connect to xenon!
Post by Waltomatic »
Alfaeddy wrote:But this switch replaces all adapters (A1, A3, A4 purple)
OK!
Racing, you can include 12-7 in it, respecting the disconnection of 7 when linking with 12.
Racing Man
Waltomatic wrote:Racing, you can include 12-7 in it, respecting the disconnection of 7 when linking with 12.
I've tried that way, but it don't connect with the xeno ecu...
In normal operation, just switching the wire 7 from pin 7 to pin 12, it doesn't connect... So, seeing adapter #1, where 7, 9, 12, 1 are linked toghether, maybe to connect with xenon pin 7 and 12 must be joint together to wire 7?
No, according Supported Vehicles you need the same A3. You welded wire on pin 12 of connector?
Racing Man
No, I've only put a switch on wire 7, that connects pin 7 or pin 12. Should I weld pins 7 and 12 together? Why the same A3? In this picture is shown A1 :|
Schermata 2015-02-16 alle 19.14.46.png (96.13 KiB) Viewed 8418 times
Cáspita!!! Você não disse que era do Alfa, kkkkkkk
Meu conselho: esqueça a adaptação para o Alfa e compre um cabo.
Racing Man
Waltomatic wrote:Cáspita!!! Você não disse que era do Alfa, kkkkkkk
I've written it few pages before, I forgot to repeat it! :P
And that's why I've welded some pins together before!!! :D
I've to try to weld together pin 7 and 12 to wire 7, and see what happens... :D
Let It Be...
Well, as I said it would be more accurate to buy the adapter 1, but you may even be able to. Each adapter connects a wide variety of vehicles and systems, and perhaps Alfa not need all the wires together. Hopefully, only 12-7. My diagram allows this option.
