ELM327 v2.1 support
veskoy
ELM327 v2.1 support
Post by veskoy »
Is it possible to make multiecuscan support elm327 v2.1? There are many devices that come with v2.1.
Re: ELM327 v2.1 support
I guess you are talking about clone ELM 327 ver. 2.1 interfaces...
I think more less they are all versions that are written as 2.1 in general they are 1.4 versions...
It is just they write something in advertisement and the people thing it is a true...
MES have support for ELM 327 interface which is minimum 1.3 version.
Higher version should work more lees without problem...
Franklincj
Post by Franklincj »
It's great to do? I want to be
Herpez
Post by Herpez »
It's being said here
"viewtopic.php?f=5&t=1493&start=1840"
that MES doenst work with v2.1.
This error does not refer only to the ELM 327 v2.1
the versions 1.5 are not compatible with MES
Here's a test of some of my many ELM 327 Interface
which are not always compatible
as you can see in the screen
In only Yani can provide information
ELM327 v1.5 Fehler.jpg (39.04 KiB) Viewed 8750 times
